4cyl accord low idle and ruff idle
Old May 17, 2006 | 02:47 PM
lc4132's Avatar
Default 4cyl accord low idle and ruff idle
It is running prety ruff and low idle rpm
I did a toon up and I put in a high output alt to compensate for the audio draw
An suggrestions
And damb it feels like a boat w/ no pwr steering
Old May 17, 2006 | 04:47 PM
hondadude's Avatar
Default Re: 4cyl accord low idle and ruff idle (lc4132)
well on your 82 accord I'd have to say you need to check the float levels on the carb. There is a little glass window on the drivers side of the carb. The gas level should be seen thru that window. Maybe the floats are sunk and the carb is dumping fuel.
Old May 17, 2006 | 04:53 PM
lc4132's Avatar
Default Re: 4cyl accord low idle and ruff idle (hondadude)
Its a 95 2.2 lx
Old May 17, 2006 | 08:50 PM
HONCORD's Avatar
Seems like iac valve needs to be cleaned. there is another valve under your throttle body cant think of the mane of it. It has been brouht up a while back. had picture and all of how to remove it.
Old May 18, 2006 | 07:13 AM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
did you check your dostributor????
Old May 18, 2006 | 08:13 AM
lc4132's Avatar
Default Re: (I got the CD5 Jeebies!)
Yep
New alt / therm / wires / plugs / oil & filter / rad fluid / air filter
I also ajusted the throttle cable
And I have no ac so its not that, I removed all ac and cruise control components
Dionili Securio
Aug 27, 2018 04:55 PM
zlambz71
Mar 20, 2018 08:46 PM
MarcosMarcusM
Oct 26, 2008 09:02 PM
sun_zinc
Jul 13, 2008 01:19 PM
rcjordan5749
Jul 16, 2007 11:37 AM
