do they use the same wire harness ?
i currently run a jdm b16 SIR II with a jdm ITR ECU OBD2 in my 97 civic . will a stock sohc d16 vtec from a 96-97 civic be the same wire harness ?
how hard would it be to swap back to a SOHC D16 ?
what parts can i use that im currently using right now ?
i was told a while back that they can use the same engine harness but im not sure.
thanks in advance .
thanks in advance .
what else can i use from my b16 sir II that i can use on the d16 install ? i know the engine mounts are the same , but what else ? exels ?
twisted_jdm_b16
May 18, 2006 12:47 AM
Tyson Ballou
Nov 19, 2001 09:34 AM
