Alarm for parking structure
Old May 17, 2006 | 11:54 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Alarm for parking structure
It's been a while that I shop for an alarm.
I park in a multilevel parking structure at work, that trigger all alarms when ever cars go by (because of echo, weight, etc).
If set a normal, my alarm will go off 1,000 times a day. If set too low, it will not make a sound when the bad guys are jacking it with a hammer.
I know one can adjust the sensativity. However, I can't go under the dash (or where ever the brain will be) to adjust it everyday.
Are there alarms that can adjust the sensativity as easy as a switch?
TIA
Old May 17, 2006 | 06:24 PM
JSPECSIR's Avatar
Default Re: Alarm for parking structure (GoLowDrew)
viper 1000 and 5000 are adjustable from the remote. the 5000 is a responder unit that has a bar graph on the screen to show you how it is set as well.
http://www.directed.com
check em out.
Old May 17, 2006 | 06:28 PM
tha_badguy's Avatar
sounds like they trigger only shitty alarms
dual-stage shock sensors
will keep that from happening
iCollectStraws
Audio / Security / Video
Jul 7, 2009 12:28 AM
gus738
Honda Civic (2006 - 2015)
15
Dec 19, 2006 09:26 PM
forumnoobie
Sep 14, 2006 08:32 AM
blktyper919
11
Mar 7, 2004 05:10 PM
seer_claw
11
Mar 1, 2004 02:45 PM
