HOW DO I GET THIS OFF MY BLOCK????
Old May 16, 2006 | 11:32 PM
B18 CYA's Avatar
Default HOW DO I GET THIS OFF MY BLOCK????
how do you get that peice around the crank off. the peice i am talking about it on the outside of the block and around the crank, there is a few bolts holding it on, when you look on the inside there is 3 philips screws that look like there holding it on, do i have to take those out? casue the caps for the crank are in the way of getting at them?
im trying to transfer everything from 1 gsr to another bare block. and i dont wanna take anything else apart on the first one.
any help would be fantastic!
this is what im talking about, not my engine, but a pic i found.
edit--- changed the pic for you guys
Modified by B18 CYA at 8:48 AM 5/17/2006
Old May 16, 2006 | 11:34 PM
HyperX's Avatar
are you talking about your timing belt cover?
Old May 16, 2006 | 11:41 PM
B18 CYA's Avatar
Default Re: (HyperX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HyperX &raquo;</TD></TR><TR><TD CLASS="quote">are you talking about your timing belt cover?</TD></TR></TABLE>
no, pics added.
Combustion Contraption's Avatar
I dont see any pics.
edit: there we are. That looks like your referring to your lower timing cover but you already said no to that.
Old May 16, 2006 | 11:42 PM
Spracer03's Avatar
he's either talking about the oil pump or the rear main... take out all the bolts on the outside n pry it out a lil with a flathead.. should come right out
Old May 16, 2006 | 11:44 PM
B18 CYA's Avatar
Default Re: (Spracer03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spracer03 &raquo;</TD></TR><TR><TD CLASS="quote">he's either talking about the oil pump or the rear main... take out all the bolts on the outside n pry it out a lil with a flathead.. should come right out</TD></TR></TABLE>
so you dont have to take out the philips screws on the inside of the engine?\
i took out all the bolts and it didnt move, then when i flipped it over, i noticed those screws inside...just wanna know first before i start taking other stuff off i dont have to
Old May 17, 2006 | 12:46 AM
texastype_r's Avatar
Default Re: (B18 CYA)
if you dont know how too take it off you probably shouldn't be doing it !!!!!!!!!!!!
Old May 17, 2006 | 12:50 AM
Spracer03's Avatar
lol, no you gotta remember someone, or something had to put it on.. so it cant be impossible to get to the screws/bolts a pic would really help
Old May 17, 2006 | 02:51 AM
Ovrbst_T66's Avatar
Look like your trying to get the oil pump off.take all the 10mm bolts off,take the crank pully of,take the timing cover off,then take the timing belt gear off and the pump should come off with ease.if you cant do it yourself i would recomend you take it to someone that knows what they are doing.
Old May 17, 2006 | 04:03 AM
Slamaccord's Avatar
Default Re: (danny_t66)
Is that motor inside your car LOL
Old May 17, 2006 | 05:47 AM
Chris22215's Avatar
Default Re: (Slamaccord)
are you talking about the crank angle sensor on the obdII blocks?
Edit: looking at the pic, you wouldn't be talking about the oil pump would you??
Old May 17, 2006 | 06:55 AM
UncleD's Avatar
Default Re: (Chris22215)
To get the oil pump off you do not have to remove the screws from the inside. They Honda-bond the **** out of them so you need to gently tap a flat head screw driver in to pop it off.
Old May 17, 2006 | 08:15 AM
nvmyb20hatch's Avatar
Default Re: (clean rice)
you have to take off the oil pan, the oil pickup is attached to the oil pump inside the pan. theres 4 10mm bolts and 2 12mm bolts holding on the oil pump.
Old May 17, 2006 | 10:06 AM
B18 CYA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">To get the oil pump off you do not have to remove the screws from the inside. They Honda-bond the **** out of them so you need to gently tap a flat head screw driver in to pop it off.</TD></TR></TABLE>
this man was right, i had to use a hammer though i couldnt pry it off with a screw driver
alpha
Jun 19, 2007 08:35 PM
EKHB
Feb 14, 2007 11:04 PM
ZippyZivic
19
Feb 8, 2007 07:32 AM
dc4teg95
Jan 16, 2007 09:33 PM
Sinner
Sep 9, 2004 08:03 PM
