Sunroof wont open
Old May 16, 2006 | 10:52 PM
mike001's Avatar
Default Sunroof wont open
I have a honda accord 2002 ex and it has a sunroof. I dont no what happen but that sunroof wont open anymore. When i press the button to open the sunroof i only hear the noice, its like the noice when you open your sunroof but it doest open. The sunroof only opens up, its doest open on the side. Please help i need to fix it as fast as possible. Tnx
Old May 17, 2006 | 04:47 AM
Ross 2.0's Avatar
In a Junkyard near you.
What do you mean on the side?
In your jack tools or in the glovebox you have a small wrench, get it out and sit in your back seat, take the plastic plug out of the headliner and you will be able to open the sunroof using the tool.
If you can't even open it that way you have a mechanical failure, (probably lack of lubrication). You may be able to free it up by spraying some white lithium or sillicone on the track and levers.
See if it clears up then, if not you may have a position switch that has gone bad.
Storey12
Honda Civic (2001 - 2005)
Jul 14, 2018 02:10 PM
mvp4unc
Apr 17, 2017 08:01 AM
anlee
Jul 10, 2011 09:44 PM
serr38
May 10, 2009 03:39 PM
haggard hatch
Mar 21, 2002 03:47 PM
