Axels for B swap...I searched but did not find exactly a for sure answer
Old May 16, 2006 | 06:19 PM
NAIIAWAH's Avatar
Default Axels for B swap...I searched but did not find exactly a for sure answer
If I was to use a jdm y1 or si...which mid shaft and axels will I need to get? I heard that the 90-91 integra axels will work but will a 90-91 mid shaft bolt up in our car? Also last question is the y1,s1, j1...will the 90-91 teg midshaft and axels work with either of these tranny's? Also last but not least I do have to remove the bust seals from the civics hubs right? Thanks
Old May 16, 2006 | 06:21 PM
CRXBart's Avatar
Default Re: Axels for B swap...I searched but did not find exactly a for sure answer (NAIIAWAH)
I got both axles and a intermediate shaft. hit me up if you want them.
Old May 16, 2006 | 06:39 PM
jacoop86's Avatar
Default Re: Axels for B swap...I searched but did not find exactly a for sure answer (CRXBart)
to answer your question the only cable b series half shaft that wont work with 90 integra axles is the sh3 intermediate shaft that came with the y1 tranny. you can use the y1 with a 90 integra axle/intermediate shaft combo. if you use the sh3 shaft then you will have to get a custom left axle (to compensate the different shaft length) and the 90 integra right axle. if you use the s1 or j1 tranny with the sk7 shaft (same as 90 integra) just get a pair of 90 integra axles. no matter what intermediate shaft/axle combo you use, take out the dust caps from the hubs like you said.
Fate
10
Dec 29, 2005 01:57 AM
shawn_crx
Jul 27, 2005 03:26 PM
90hbvtec
Oct 28, 2003 06:10 AM
chirp2hrd
May 20, 2003 06:59 AM
Black R
Dec 2, 2002 05:04 PM
