A few quick questions on my swap..
Old May 16, 2006 | 02:05 PM
deanh8's Avatar
Default A few quick questions on my swap..
Im putting a 1991 Integra LS engine in a 91 std hatchback, I need to know if 94+ integra axles work and will a b16a pr3 dizzy work with a b18a1 and a pr4 ecu. Also, which alternator do I need, d series one wont work right?
Old May 16, 2006 | 02:07 PM
ludesrv's Avatar
Use the LS alternator, bash the frame in a bit for the crank pulley to fit in nice with a mounting kit. ECU is the right one, dizzy won't work at all. Won't mount good and won't run right, trust me.
Old May 16, 2006 | 02:25 PM
crxnj's Avatar
Default Re: (ludesrv)
the passenger side axle will work..you might need to get a 94+ integra axle seal though,,otherwise it may leak a bit..and for the driver side axle you need to get a 94+ intermediate shaft,,but does that intermediate shaft bolt up to the B18a engine?? im not sure..
oh and you realize you'll need different hubs since you have a std..? any 88-91 si/dx/lx/ex hubs will work..
Old May 16, 2006 | 02:45 PM
deanh8's Avatar
Default Re: (Mr.speaker)
I have LX hubs already.
Old May 16, 2006 | 05:10 PM
95_red_dc's Avatar
Default Re: A few quick questions on my swap.. (deanh8)
for the axles you will need 91 integra axles to match the half shaft a 94 axles and half shaft will not bolt up i had ran into this problem when i did my b18b swap in my crx i had to use 94 drivers side axels with the 94 half shaft and i had to use a 94 axles seal
Old May 16, 2006 | 07:17 PM
deanh8's Avatar
Default Re: A few quick questions on my swap.. (91cleancrxsi)
What about the alternator, any b series one work?
I need 90-93 LS Axles,
90 - 91 LS dizzy
and any b series alternator or an LS one?
Old May 16, 2006 | 07:21 PM
deanh8's Avatar
I found an alternator from an 88 integra ls, will it fit?
Old May 16, 2006 | 07:27 PM
Crx Jimmy's Avatar
no get one for a b series
Old May 16, 2006 | 08:12 PM
deanh8's Avatar
Default Re: A few quick questions on my swap.. (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">no get one for a b series</TD></TR></TABLE>
What motors did the late 80's integras have?
Old May 16, 2006 | 08:23 PM
93cavRS's Avatar
zc's i do believe?
Old May 16, 2006 | 08:28 PM
CRXBart's Avatar
I have the alternator, and the axles, and the intermediate shaft. PM if interested! I'll make you a great deal. I need to get rid of my b series stuff.
mjfx
Apr 22, 2008 07:42 PM
SoHc94
Feb 9, 2007 06:00 PM
95_red_dc
Apr 24, 2006 07:02 AM
xH22xTEGx
Jan 12, 2006 06:48 AM
Blazeone
Jul 27, 2004 05:55 AM
