fuel pump fuse?
Old May 16, 2006 | 02:04 PM
halozero's Avatar
Default fuel pump fuse?
so, last tuesday, i went to my car, started, pulled a Uey and started to drive home from class, all of a sudden the car dies as if i had cut the fuel line. i pop the hood and check to see if i may have been leaking anything, all seems clean and good to go, but the car won't restart. so i wait about 10 minutes, starts and off we go.
then again, today, tuesday, at the same time, doing the same thing, she did it again! took about 15 minutes for her to restart this time.. this post was going to be a lot more broader until i spoke w. a classmate and they said they had a problem w. their fuel pump fuse, located near the pump. described what happen to them it was exactly the same... car acted like you flipped a kill switch and off it went.
now i've done some work back there but i haven't seen any fuses.. she says its there but i don't see it, any truth to this? or could it be a fuse up front in the dash?
thx in advance.
-halo
Old May 16, 2006 | 02:11 PM
ludesrv's Avatar
It's your main relay. Not a fuse. The solders break in them. You can either replace it with a new honda one which the problem has been corrected, or you can resolder your old one for next to nothing.
93eg1
14
Oct 26, 2010 03:36 PM
97civic07gsxr
15
Jan 14, 2009 06:25 PM
4banger1986
Nov 26, 2008 11:13 PM
.ShawnD.
Oct 2, 2008 04:01 PM
