Jacked car in the air to spin ITR LSD trans. Only one wheel spins...
Old May 16, 2006 | 01:09 PM
. M i c h a e l's Avatar
dotmichael to you
Default Jacked car in the air to spin ITR LSD trans. Only one wheel spins...
I spun both wheels, the opposite wheel doesnt move at all. Turned the car on and put it in gear. Both are moving.
I know this isnt the best way to check for LSD...but shouldnt the opposite wheel being spun move?
Old May 16, 2006 | 01:45 PM
x2gold's Avatar
Default Re: Jacked car in the air to spin ITR LSD trans. Only one wheel spins... (. M i c h a e l)
both wheels spin the same way in posi..if it's open...the one spins one direction, while the other spins the opposite. Posi/LSD, both wheels spin in same direction. You are correct to jack it up( both wheels and watch tire rotation.
Old May 16, 2006 | 01:48 PM
dotmichael to you
Default Re: Jacked car in the air to spin ITR LSD trans. Only one wheel spins... (x2gold)
Thing is...I spun each wheel...and nothing happened to the other one.
Old May 16, 2006 | 01:53 PM
x2gold's Avatar
did u just install, or get the motor ? How many miles on the diff/tranny? the more miles, the weaker the springs can be, also this depends on the type of diff used.
x2gold's Avatar
go lay a patch, see if it's one wheel or two
Old May 16, 2006 | 01:54 PM
dotmichael to you
The motor is a jdm b16a from hmotors with less than 50,000 on it. The trans was bought brand new in November and has about 3,000 miles on it.
dotmichael to you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x2gold &raquo;</TD></TR><TR><TD CLASS="quote">go lay a patch, see if it's one wheel or two </TD></TR></TABLE>
This has been proven to be inaccurate. My old 89 civic si with a sohc zc swap would lay two strips.
Old May 16, 2006 | 01:55 PM
x2gold's Avatar
damn, brand new... dealership order? ..not sure why it wouldn't spin both tires then.
Old May 16, 2006 | 01:56 PM
dotmichael to you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x2gold &raquo;</TD></TR><TR><TD CLASS="quote">damn, brand new... dealership order? ..not sure why it wouldn't spin both tires then.</TD></TR></TABLE>
Yeah, from the dealership.
Old May 16, 2006 | 01:58 PM
x2gold's Avatar
well, you are correct on that, but I just tore apart my ls tranny to put in a lsd unit two weeks ago. I have the open diff in my shop. Like I said before, one side turns one way, the other turns the opposite. The lsd, both sides move in same direction. This tranny hasn't been installed yet, waiting on some motor parts...but this was with the tranny on a bench.
Old May 16, 2006 | 02:17 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . M i c h a e l &raquo;</TD></TR><TR><TD CLASS="quote">I spun both wheels, the opposite wheel doesnt move at all. </TD></TR></TABLE>
Gear type lsd? That's the way my obx works.
Old May 16, 2006 | 02:34 PM
dotmichael to you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Gear type lsd? That's the way my obx works.</TD></TR></TABLE>
I do not know. whatever the LSD in the USDM ITR trans is.
Old May 16, 2006 | 02:40 PM
x2gold's Avatar
Default Re: Jacked car in the air to spin ITR LSD trans. Only one wheel spins... (Chiovnidca)
exactly..there are two types, gear / or cone/clutch type..i'm not too familiar with honda lsds. Either way, both wheels should still spin. The second type needs pressure to active, therefore you should spin one, and the other might not turn.
Old May 16, 2006 | 03:12 PM
dotmichael to you
car needed to be in gear for it to work.
car has lsd.
Old May 16, 2006 | 03:18 PM
Dogginator's Avatar
Daisy... Daisy...
Your situation is normal for a helical (ITR) LSD.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Check it like you would check an ITR LSD (from the Helm manual):
Operational Check
Set the parking brake and block the rear wheels.
Raise the front of the vehicle, and support it with
safety stands in the proper locations( see section1 ).
With the engine off, shift the transmissionin to 1st gear,
Rotate either front wheel bv hand and check that
the other wheel rotates in the opposite direction.
lf the opposite front wheel does not rotate, or if vou
cannot spin the front wheels at all, the limited slip
differential is faulty and should be roplaced.
Rotating Torque Check
1. Setting parking brake and block the rear wheels.
2. Raise the front of the vehicle, and support it with
safety stands in proper locations( see section1 ).
3. With the engine off, shift the transmission into
Neutral.
4. Measure the rotating torque with a beam-type
torque wrench in the direction shown (top towards the rear of the car), Rotate the
torque wrench more than two complete turns and
take the maximum reading.
5. Shift the transmission into 1st gear and measure
the rotating torque again.
6. Calculate the rotating torque:
Service Limit:
(Measurement from step 5)/(Measurement from step 4) &gt;=2.5
7. Repeat steps 3 through 6 for the other wheel.</TD></TR></TABLE>
https://honda-tech.com/zerothre...01367
Old May 16, 2006 | 03:23 PM
dotmichael to you
Default Re: Jacked car in the air to spin ITR LSD trans. Only one wheel spins... (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Your situation is normal for a helical (ITR) LSD.
https://honda-tech.com/zerothre...01367</TD></TR></TABLE>
another member JUST posted that about 10 minutes ago. I was testing with it neutral. Put it in 1st and no problems.
thanks for finding the link though.
C5teg
Dec 21, 2007 01:17 AM
Hittnthebz
Sep 20, 2007 10:35 AM
. M i c h a e l
May 17, 2006 12:51 PM
speedminded
Sep 5, 2004 06:49 PM
speedminded
Sep 5, 2004 06:26 PM
