Z6/B7 mini me troubles?
Old May 16, 2006 | 10:48 AM
aquabob89's Avatar
* B A N N E D *
Default Z6/B7 mini me troubles?
Well the problem is that after about 3k the car starts to die, it will make to 7k. From 3k to 7k it seems like it gets way weaker and like the ignition isnt igniting. I dont know what to do ive been dealing with problems of this sort for a while. Any suggestion are helpful. Thanks.
95 dx coupe
min-me z6head/b7block
Old May 16, 2006 | 11:00 AM
FalkenSiR's Avatar
Default Re: Z6/B7 mini me troubles? (aquabob89)
Did you go through the Write-up by Bauley? If not, do it and see if you missed anything.
Are you throwing any codes?
What dizzy are you using?
Old May 16, 2006 | 11:03 AM
aquabob89's Avatar
* B A N N E D *
Default Re: Z6/B7 mini me troubles? (fast95eg9)
Yes i throw code/codes. and Yes I did the write up. (guess not though). One of my problems is i have an extra hose coming out of the thermastat. Also I have no charcoal canister.
Old May 16, 2006 | 11:06 AM
FalkenSiR's Avatar
Your problem is wiring-related. However, you should get the coolant line and the charcoal canister fixed up, if you want to pass smog anyways.
What codes?
aquabob89's Avatar
* B A N N E D *
dam just read somewhere about my same kinda problem. it said bad ecu changed it and fixed the problem.
FalkenSiR's Avatar
What ecu and codes?
aquabob89's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg9 &raquo;</TD></TR><TR><TD CLASS="quote">Your problem is wiring-related. However, you should get the coolant line and the charcoal canister fixed up, if you want to pass smog anyways.
What codes?</TD></TR></TABLE>
I live in SC im straight for smog
Old May 16, 2006 | 11:09 AM
FalkenSiR's Avatar
You know what, you need to bleed your vtec.
Hond@
Dec 22, 2010 08:20 PM
mikej94civex
15
Jan 6, 2010 02:46 PM
Giken Kogyo
Jun 22, 2007 06:25 PM
Chronicsinners
35
Jan 28, 2005 04:35 AM
Waachback
14
Nov 28, 2003 01:36 PM
