is my setup good for 220-230 whp..
[-] gsr block rs machine sleeved/bored at 85.00mm
[-] ls crank, eagle rods, je 12.5 cr pistons.
[-] gsr head alaniz comp. port.
[-] blox hsl cams.
[-] skunk2 intake manifold, polished/port matched
[-] rpm 70mm throttle body
[-] hytech header
[-] p28 with hondata
my goal is to hit 225 whp.
[-] blox hsl cams.
[-] hytech header
What other cams are the Blox HSL cams comparable to? What are you using for an intake; and exhaust? Are you using the Hondata S300? All of the above are important variables. The tuner of course is the most important variable.
Those numbers shouldnt be a problem at all to reach. The im may hold ya back a little but with that setup higher numbers def possible good luck
Isnt this thread against forum guidelines?
Come on, youre asking if a 2038(or so)cc engine with a ported head, 12.5:1 c/r , top of the line header and engine management can hit 225hp. It better or your an ***.
It wont hit it with 50% leakdown on all cylinders though which is what will happen if YOU assemble it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tomcat »</TD></TR><TR><TD CLASS="quote">What other cams are the Blox HSL cams comparable to? What are you using for an intake; and exhaust? Are you using the Hondata S300? All of the above are important variables. The tuner of course is the most important variable.
i would also like to know this.
</TD></TR></TABLE>i would also like to know this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hi-Powered »</TD></TR><TR><TD CLASS="quote">just got back from the dyno.
227 whp and 151 tq on a dynojet.</TD></TR></TABLE>
Can you post the graph?..
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lvcrx »</TD></TR><TR><TD CLASS="quote">i would also like to know this.</TD></TR></TABLE>
s2s3
s2s3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16C1 »</TD></TR><TR><TD CLASS="quote">
s2s3</TD></TR></TABLE>
wrong. Nothing like the s2s3. The HSL cam has BIG primaries on it, s2s3 primaries are not all that big.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheepey »</TD></TR><TR><TD CLASS="quote">wrong. Nothing like the s2s3. The HSL cam has BIG primaries on it, s2s3 primaries are not all that big.</TD></TR></TABLE>
i'm pretty sure Tbone told me that the hsl is pretty much s2s3's. have you measured both the hsl & s2s3's?
i'm pretty sure Tbone told me that the hsl is pretty much s2s3's. have you measured both the hsl & s2s3's?</TD></TR></TABLE>
Yes I have........s2s3 duration is in the 270s and HSL is in the 260s..... @ .050.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tomcat »</TD></TR><TR><TD CLASS="quote">What other cams are the Blox HSL cams comparable to?</TD></TR></TABLE>
Pro-1
Pro-1
Honda_Fanatic
16
Jan 19, 2008 01:41 PM
