when u re-build a motor, what is involved?
I fucked my motor up on the highway the other day due to low oil so now I need to re-build a used motor. I was thinking of putting new crank bearing (if that is what they are called) and new piston rings. Is there anything else that I should put while the motor is out? How about a new oil pump, water pump and whatever else is there?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">I suppose if you have to ask, you shouldn't try to rebuild your motor.</TD></TR></TABLE>
Agreed. If you want to rebuild your motor, you need to read up and research about it first, not just rebuild your own motor because you have to.
