h22a injector problem
Old May 15, 2006 | 06:48 PM
zamrioo2's Avatar
Default h22a injector problem
guys... sorry for asking...
i'm running 90 pr3 b16a with h22a injectors with vafc2... i'm facing with rough iddling, hard to start when the engine hot and engine'll self off after i floor the paddle... is it due to saturated injectors...? do i need to install h22a ballast...? technically what happened...?
Old May 15, 2006 | 07:10 PM
zap's Avatar
zap
your too rich. thats why your car dies when you step on the gas.
get an engine management software and tune your motor.
if your motor is stock, stick with the stock b16a injectors and you'll be fine.
Old May 15, 2006 | 11:04 PM
crxnj's Avatar
Default Re: h22a injector problem (zamrioo2)
yeah those injectors are larger so get the vafc you have tuned for them or just put back in the stock 240cc's....also with those saturated injectors you'll want to get rid of the stock resistor box,,..
Old May 18, 2006 | 03:10 AM
zamrioo2's Avatar
Default Re: h22a injector problem (Mr.speaker)
i'm juz curious where the resistor box located...? no idea at all... huh...
Old May 18, 2006 | 04:20 AM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zamrioo2 &raquo;</TD></TR><TR><TD CLASS="quote">i'm juz curious where the resistor box located...? no idea at all... huh...</TD></TR></TABLE>
Drivers side corner of the bay near the windshield usually.
Like noted earlier, I'd put the stock injectors back in until you can get the car tuned. It will continue to bog/die because it is running to rich.
evo
14
Aug 13, 2021 05:02 AM
98h22avtec
Jun 18, 2016 10:56 PM
accord2civic2prelude
Jan 29, 2010 09:10 AM
djnikko
May 19, 2006 06:29 AM
altoid
Feb 5, 2003 08:10 AM
