Back seat removal?
Old May 15, 2006 | 05:26 PM
frankenstang57's Avatar
Default Back seat removal?
Hey, how do you get the lower half of the rear seat out? I don't want to prye on it too much and bend the springs. Any suggestions?
Old May 15, 2006 | 05:48 PM
mattf22b1's Avatar
Default Re: Back seat removal? (frankenstang57)
there are two clips if i remember correctly that go into the body of the car, lift the seats towards the front of the car and then pull, you'll have to put some effort into it...why are you taking the back seats out anyway? that's for a 4th and 5th gen i would assume its the same for a 6th but i wouldn't know as you didn't put the year of your accord
Old May 15, 2006 | 05:52 PM
departed's Avatar
Default Re: Back seat removal? (mattf22b1)
take out the mat in the trunk and there should be at least two bolts back there... what year is the car?
Old May 15, 2006 | 06:10 PM
philadd's Avatar
Default Re: Back seat removal? (departed)
The rear seat bottom on my 6th gen sedan comes out by just yanking up on the front of the cushion.
Old May 15, 2006 | 09:14 PM
Heat's Avatar
Default Re: Back seat removal? (philadd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">The rear seat bottom on my 6th gen sedan comes out by just yanking up on the front of the cushion.</TD></TR></TABLE>
There's also a bolt that has to be taken out on the 6th generation. Imagine the seatbelt buckle for the person sitting in the far left position - the bolt is right behind that (in the crevass) if I remember correctly. Then yes, just pull up on the front.
Old May 15, 2006 | 09:42 PM
departed's Avatar
Default Re: Back seat removal? (Heat)
I just looked in the haynes manual for the 98 and 99's... there is a *supposed* to be one bolt accessible from the trunk under the carpet
Old May 15, 2006 | 10:07 PM
Heat's Avatar
It was assessable from the crevass in my '99 though I didn't try to access it from the trunk.
Take a look at step 33 in these instructions:
http://www.handa-accessories.c...k.pdf
Old May 15, 2006 | 10:50 PM
philadd's Avatar
Strange.. I've never had to deal with a bolt. I've always just yanked up and pulled it out without any problems
Old May 16, 2006 | 02:40 AM
92ehatch's Avatar
seat in my 4th gen had 2 bolts on the back corners of the seat, one in the center accessible after taking top part out.
then there was some sort of glue type substance holding it down, just yank it hard man
Old May 16, 2006 | 05:33 PM
Default Re: Back seat removal? (93cb7sedan)
I'm taking the seat out to power wash it. the people who owned the car before me were total pigs, and it's disgusting. I found the bolt for the top OK, there are none at theback. It's hooked in the front somehow. I'll take a look for clips. Thanx!
Old May 16, 2006 | 08:28 PM
Heat's Avatar
What year is your Accord?
Old May 17, 2006 | 05:45 PM
D'OH! I guess I got you guys confused with a psychic forum. It's a '90. Sorry about that!
ohm13
Honda CR-V & Element
Oct 29, 2016 07:30 AM
us31wking
Dec 21, 2007 02:34 PM
AndyD
May 4, 2004 04:30 PM
DrunkNRacer
Jan 8, 2004 03:18 PM
The G2 Racer
Feb 20, 2003 02:24 PM
