is my motor no good or not?
Old May 15, 2006 | 04:46 PM
dev's Avatar
dev
Default is my motor no good or not?
my fully rebuilt motor started to knock. went to check it out and i seen that the crank pulley had got loose. will this cause the motor to be off balance and knock. i'm praying that it's still good. help me out here.
Old May 15, 2006 | 05:25 PM
boosted civic 2k6's Avatar
Default Re: is my motor no good or not? (dev)
using a long flathead stethiscope method (SP), try and locate where the sound is coming from. Is it coming from the pan or the valve cover. a loose crank pulley would make a vibration noise. why dont you fix it and see before you ask.
PR8urVtec
Aug 24, 2010 11:24 AM
JSmith8
Dec 13, 2009 08:52 AM
Bac91Da
May 30, 2008 04:14 PM
AnthraxVX
Apr 23, 2006 03:41 PM
88 rex
11
Aug 25, 2005 09:14 PM
