NEED HELP VERY QUICK please read !!!!!!!!!!!!!
will it fit.... yes... will it work.. should be your question... guys correct me if im wrong.. but doesnt that require some wiring?? since the si has a tach and std doesnt... i could be wrong but i think thats what i heard before..
nah now wiring just plug n play it is simple most of us little guys that get a car without a tach either buy the aftermarket one or get the new cluster...........but it is simple just plug it in..........good luck you will need to reset your mileage to your car but other then that your good......
its that simple.. you just hook it up.. well ****.. my dx will soon have an si cluster if thats the case.... lol
just put it in...it works put one in my cousins 91 std and it worked fine but we COULD NOT get the fuel gauge to read correctly...tried everything but it was stuck where the other car left off
remove the negative terminal from your battery first.
otherwise you can kill the fuel guage, like mentioned above.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxtosirex »</TD></TR><TR><TD CLASS="quote">yes. my buddy put a 88 crx si cluster in to a 91 std hb. so it should work.</TD></TR></TABLE>
thats not just plug and play though..
yes you can put a 90 si cluster in your 90 std,,its plug and play..just remember to disconnect the battery like said when you do it..
SyLee Duk
May 26, 2003 03:29 PM
virginia_dude
Feb 6, 2002 04:47 AM
