accord 91 door
Old May 15, 2006 | 04:16 PM
fuel.Injected.Life's Avatar
Default accord 91 door
i was wondering if anyone knew how to remove the driver-side inside door panel of a 91 accord lx 2 door....
Old May 15, 2006 | 06:21 PM
knucklehead11's Avatar
Well I have a '91 EX but I'm sure it's the exact same. First off, it depends if u have manual crank windows or power. In my case, I have power windows. You unscrew the screw behind the door handle, in the handle of the door panel's arm rest, one where the panel meets the dash, and I believe those are all the screws. Get a big flat blade, and gently begin prying the panel away from the door on the edges. What I did was start at the top end where the panel meets the dash and just slowly and carefully pulled it back with my hand some, and just slowly popped the plastic anchors out. After it's all out, gently push upward to remove the panel, and be careful of the door handle as you have to kinda tilt and move it to where you can let it go through the hole to the other side of the panel.
CXHatchback
Mar 7, 2020 09:21 PM
Agent00J
Oct 7, 2008 08:11 PM
bobkatzzz
Oct 21, 2005 05:28 PM
