Si engine Harness Question
Are the 88-91 crx si engine harnesses the same as 88-91 civic si hatch engine harnesses?....my car is a 89 civic si....also, are they interchangeable amongst themselves (years)?....for example: can i use a 91 civic si engine harness in my 89 civic si ?
Last Question: Does anyone know if i need to do anything to an si engine harness for a B18a1 pr4 to work properly?
I am 95% sure they are. Same obd0. With the pr4, just make sure you plug into all the same sensors as the sohc. I think the pr4 has its iacv/idle regulator on the firewall instead of the intake manifold.
slpnz....do u know if the 88-91 crx si engine harnesses the same as 88-91 civic hatch engine harnesses.....i have tried to research it, but no one can give me a deffinant answer to it.
example: will the 89 crx si harness fit in my 89 civic si hatch?
89 CRX and Civic Si engine harness have the same part no. - 90-91 CRX and Civic Si have same part no. but part no. is different from 89 - don't know what is different
thanks...hey umm...i replied to that message in question with that HF manifold..
hey the part on the left (canister looking thing) is the EGR valve?.....on my b18a1 in my 89 civic si i have the same thing on the manifold...but i dont see anywhere to plug it in at??.....any suggestions???...do i need it?
trooper0641
Mar 3, 2008 06:50 PM
