clutch removal....what else is needed?
Old May 15, 2006 | 02:38 PM
redpeppers's Avatar
Default clutch removal....what else is needed?
Other than the clutch kit....what else is needed to put a stock clutch on my 97 civic cx 1.6 nonvtec.....oils, grease, etc.? (Exclude tools)
Old May 15, 2006 | 02:40 PM
postman's Avatar
Default Re: clutch removal....what else is needed? (redpeppers)
new trans fluid, rtv
Old May 15, 2006 | 02:45 PM
t0p_sh0tta's Avatar
Default Re: clutch removal....what else is needed? (postman)
Torque wrench, jackstands and basic hand tools. The hardest part is lining the damn tranny back up when putting everything back together. Not a tough job at all though.
Old May 15, 2006 | 02:57 PM
redpeppers's Avatar
what size weight (trans fluid)
SOHC4life 96's Avatar
Default Re: clutch removal....what else is needed? (t0p_sh0tta)
A friend to help you get the tranny back on and hold some **** when you are taking **** apart and putting it back together.
Old May 15, 2006 | 03:49 PM
L8apex's Avatar
Blue loctite for the flywheel bolts. And some anti-wear grease on the clutch fork and pressure plate and throwout bearing.
Old May 15, 2006 | 04:12 PM
lv6l's Avatar
a friend or a engine hoist to put the tranny back in. that is the hardest part.
i just installed my clutch, i did it on my own, took me about 4 hours with the help of an engine hoist. hardest part, putting tranny back in. i messed up by using impact to shoot in the pressure plate bolts. you should use a torque wrench. i was too lazy to redo it so i just left it like that. you need to get some grease and grease the shift folk *****(2), and the input shaft of the tranny. i changed my clutch without having to change my tranny fluid. only a few drops fell out and it was fine. make sure you break it in properly after though. good luck.
Old May 15, 2006 | 06:24 PM
postman's Avatar
Default Re: (lv6l)
no fluid ran out the axle hole
Old May 15, 2006 | 07:31 PM
lv6l's Avatar
if you're asking me the question, no. it came out a bit when the tranny was leaning to one side. i check tranny fluid afterwards. everything is fine.
dc2LS
Oct 13, 2010 06:04 PM
91crx-jace
Jan 11, 2009 06:41 PM
fastlyfe
Oct 14, 2004 02:16 PM
90LSpimpin
Aug 18, 2004 05:16 PM
90LSpimpin
Aug 18, 2004 04:01 PM
