Removing side view mirrors help!
Old May 15, 2006 | 02:32 PM
ella94's Avatar
Default Removing side view mirrors help!
I want to take my side mirrors off for some painting. Just the top part that rotates, not the stub that connects it to the door. How can i do this? I tried rotating it both ways and pulling up on it. It acts like it wants to move but i dont want to break anything. Many much thanks..
Old May 15, 2006 | 03:15 PM
Ej1_coupe's Avatar
Default Re: Removing side view mirrors help! (ella94)
huh? are you saying that you are only taking off the part that actually encloses the mirror? To take a mirror off you will need to: Sorry I have no pics
1. remove the door panel
2. There will be a black triangle thing right where the mirror is. (on the inside of the door. )
3. Pop that black plastic piece off carefully. (making sure not to break the clips)
4. Under that there will be 3 bolts.. 8mm or 9mm that you have to remove, and a clip which you will have to remove(if you have power windows)
5. Remove all bolts and pull mirror straight out.
Hope that this helped a little.
93allmotorcoupe's Avatar
This isnt a definite answer but its something you could try. Underneath the mirror there are screw going up into the bottom of it, take those out and see if it comes out then. If not, try taking the glass out and there are screws in there holding the two outer halves together. However I think youd be better off just pulling the whole mirror off the car with the three screw holding the "stub" onto the chassis.
Old May 15, 2006 | 03:26 PM
keemosaki's Avatar
Default Re: Removing side view mirrors help! (93allmotorcoupe)
refer to the first post. its the best way to do it.
Old May 15, 2006 | 03:30 PM
ella94's Avatar
thanks fellas. as soon as im done eating will go play with it some.
Old May 15, 2006 | 04:43 PM
ella94's Avatar
Default Re: (ella94)
Tried pulling it off by twisting it a little. Didnt feel like breaking some **** so tried another approach.
Inside of the door panel. 94 del sol
Blue area is where ive went up and tried removing the bolts that hold it to the chassis
Removed those. Are those even the right bolts or what? Need some more help..
Old May 15, 2006 | 06:20 PM
ella94's Avatar
ttt need some help!
Old May 15, 2006 | 07:34 PM
EM1SON's Avatar
theres a thread with pics out there
just search
im too lazy to do it...maybe later
Old May 16, 2006 | 10:57 AM
ella94's Avatar
ttt
ive already searched. most of them refer to the first post but i need a bit more help. ive included pics..
GriFFIthS
Honda Civic (2001 - 2005)
Jul 29, 2008 08:19 AM
dets93teg
Jan 24, 2007 11:15 AM
Libertariat
Nov 16, 2006 07:52 AM
slvrcivic97
Jan 21, 2004 08:50 PM
teg94
Nov 4, 2001 05:22 PM
