does 92 teg front brakes fit 91 ef?
Old Apr 11, 2002 | 01:57 PM
civicguy's Avatar
Default does 92 teg front brakes fit 91 ef?
i just got them included with my swap,would it work?
Old Apr 11, 2002 | 02:35 PM
animatd's Avatar
Default Re: does 92 teg front brakes fit 91 ef? (civicguy)
yes
Old Apr 11, 2002 | 02:36 PM
E-AT_me's Avatar
Default Re: does 92 teg front brakes fit 91 ef? (animatd)
i have heard that the knuckles throw the alignment off tooo much. and you can't fix it.
Old Apr 11, 2002 | 03:03 PM
civicguy's Avatar
Default Re: does 92 teg front brakes fit 91 ef? (Rexman)
in which way positive or negative
Old Apr 11, 2002 | 07:03 PM
BlownB18's Avatar
It will fit but it will make the wheels stick out 10mm more than stock, just like changing the wheels to 35mm offset in stead of 45mm ( stock). Get some from a 90 4 door EX, They are 10.1" rotor and the caliper is a little bigger.
Old Apr 11, 2002 | 11:12 PM
wickedxboi's Avatar
Default Re: does 92 teg front brakes fit 91 ef? (BlownB18)
o have teg front brakes and dont have a problem with them. you need the whole front setup.
Old Apr 12, 2002 | 07:05 AM
Speed PHreak's Avatar
Yeah they'll work but they give you some postive camber. just lower your car down to fix it.
b18a1hatch
Oct 31, 2009 08:28 AM
91civicDXdude
17
Jun 21, 2003 12:32 PM
robbin
Aug 30, 2002 10:23 PM
customx_
Jan 14, 2002 04:54 AM
