~~~~~~~Anyone using Bubby Club Stage 4's camshafts?~~~~~~~
Old May 15, 2006 | 12:34 PM
BubLBack's Avatar
Default ~~~~~~~Anyone using Bubby Club Stage 4's camshafts?~~~~~~~
I just wondering if anyone out there is using these BC4 cams in a stock B18C or any b series and have had any problems with them....Or if you've heard anything, please let me know as well.
I'm deciding on which cams to get and i think these are going to be first choice.
Old May 15, 2006 | 12:54 PM
ExospeedAMcrx's Avatar
Once you go with bigger cams such as the BC4, its wise to match it up with upgraded valvetrain. To really take advantage of the power of the cam, you need to tune it for the powerband and its usually higher than the stock rev limiter, thus requiring upgraded stronger valvetrain to withstand the higher lift and prevent valve float.
We've used BC4s on stock bottom end GSRs with upgraded valvetrain and the cams and they do pretty well.
Old May 15, 2006 | 01:20 PM
GUILOTINE's Avatar
Kill Gil
Default Re: ~~~~~~~Anyone using Bubby Club Stage 4's camshafts?~~~~~~~ (BubLBack33)
heres the Dyno from the Spec IV's on my stock Block B18C
Old May 15, 2006 | 06:08 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: ~~~~~~~Anyone using Bubby Club Stage 4's camshafts?~~~~~~~ (GUILOTINE)
i had them and loved th elow/mid range on them.. great steet cam!
207whp on bubbas dyno! stock TB thru the exhaust baby!
Old May 16, 2006 | 05:22 AM
BubLBack's Avatar
Default Re: ~~~~~~~Anyone using Bubby Club Stage 4's camshafts?~~~~~~~ (FR-MOB: SnoFlake)
That's nuts!!
I am planning on getting the package deal with the BC4 camshafts, BC cam gears, Dual Valve springs and the titainum retainers....
But is that dyno right? Sorry, i'm not trying to be an A$$hole or anything....I honestly didn't think that these cam would gain that much power.... What other bolt-on's do you have? header, exhaust, CAI...???
Old May 16, 2006 | 07:41 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
yes its right in fact its the hardest Dyno to make #'s on in SOCAL.. at another dyno i made 214whp DYNOJET not a pak!
its was a 2.0L LsVtec
Old May 16, 2006 | 09:45 AM
-=Zeqs=-'s Avatar
Cams with the proper tuning can increase power insanely, especially on a 2 liter setup. But yes, different dyno's do read differently. 170 whp at SP at night. 180 at Prostreet's all motor shoot out the weekend after, in the middle of a hot afternoon. With BC3+ cams that is.
Old May 17, 2006 | 12:33 PM
BubLBack's Avatar
Default Re: ~~~~~~~Anyone using Bubby Club Stage 4's camshafts?~~~~~~~ (-=Zeqs=-)
Anyone else with dyno numbers using BC4 cams or BC3's?
Old May 17, 2006 | 12:44 PM
pornstar4777's Avatar
do rod bolts, mine stretched causing the rods to bend........rub on the crank etc...no nice......good luck though..........excellect choice
Old May 17, 2006 | 04:40 PM
strsi's Avatar
Default Re: ~~~~~~~Anyone using Bubby Club Stage 4's camshafts?~~~~~~~ (pornstar4777)
hows the idle with bc4's?
Old May 17, 2006 | 04:50 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: ~~~~~~~Anyone using Bubby Club Stage 4's camshafts?~~~~~~~ (strsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strsi &raquo;</TD></TR><TR><TD CLASS="quote">hows the idle with bc4's?</TD></TR></TABLE>
beautiful......
ill have the homie get post the vid of mine...
Old May 18, 2006 | 05:47 AM
BubLBack's Avatar
Thx for your responses guys...i appreciate all the info....
marshall12395
Nov 29, 2012 05:27 AM
BukakkEK9
Nov 3, 2006 07:31 PM
digital sol
Apr 26, 2006 10:42 AM
A2_8U
10
Oct 5, 2005 06:18 PM
matix
Sep 29, 2004 05:10 PM
