Installed new distributor.. problems...
Old May 15, 2006 | 11:03 AM
standbackimapro's Avatar
Default Installed new distributor.. problems...
Ok i installed a new distributor on my 1990 accord, I marked the timing and stuff and put the new one on the right way
But now when i go to start my car after a while of sitting it dosnt start right away, and when it starts it feels like its gonna stall out at first
Then my idle fluctuates up and down, and when it goes down it sounds like its gonna stall
Spark plugs, wires were already replaced
Old May 16, 2006 | 10:33 AM
Jmumblez2001's Avatar
Default Re: Installed new distributor.. problems... (standbackimapro)
Try adjusting the timing
Old May 16, 2006 | 11:09 AM
ilikehonda's Avatar
is it a honda dist or is it an aftermarket dist?
Old May 16, 2006 | 12:32 PM
SpeedFreak77's Avatar
Default Re: Installed new distributor.. problems... (ilikehonda)
You need to get a timing light and set the timing. Just because you set the new distributor where the old one was doesn't mean you have it exact. Set the timing and it should run correctly.
Kaminsky
14
Aug 7, 2015 03:03 PM
Euphorex
Mar 24, 2014 11:02 AM
meallout
Mar 19, 2009 11:34 AM
91smashbox
Feb 11, 2008 01:33 PM
philipkrotch
Jan 23, 2003 10:40 AM
