DOHC Tranny in my Std. What axles to use?
Old May 15, 2006 | 08:59 AM
Tippyman's Avatar
Default DOHC Tranny in my Std. What axles to use?
Ok, here's my situation. I have Civic Hatchback Std. with an SOHC ZC engine in it. I love the engine, but the tranny (stock 4 speed) SUCKS!
I want to get the DOHC ZC tranny off of HMO to replace it.
1st off, will they send me the intermediate shafts if I request them? If not, where can I get them?
Secondly, I need to use 90-93 Integra axles and remove the dust sheild, correct? If I do this, will I need to change my hubs?
Modified by Tippyman at 1:15 PM 5/15/2006
Old May 15, 2006 | 10:48 AM
jlicrx's Avatar
Default Re: DOHC Tranny in my Std. What axles to use? (Tippyman)
ask them if they have a ZC intermediate shaft - use 90-93 Integra axles and yes, you will need to swap hubs for ones from DX,Si,LX - EX, if you want the larger brakes
Old May 15, 2006 | 11:21 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: DOHC Tranny in my Std. What axles to use? (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">ask them if they have a ZC intermediate shaft - use 90-93 Integra axles and yes, you will need to swap hubs for ones from DX,Si,LX - EX, if you want the larger brakes</TD></TR></TABLE>
i thought swapping the hubs is a necessity and the larger brakes were just because that's the way they come. correct me if i'm wrong but isn't the point of swapping hubs because of the spline count on the end of the axles going into the hub and not simply for the bigger brakes (i'm sure no one would complain about getting better brakes though LOL)?
Old May 15, 2006 | 12:15 PM
Contender25
Guest
Posts: n/a
ANY HUBS besides std and hf will work, that means ONLY the dx/lx/si/ex hubs will WORK. You can use 90/91 drivers side acura integra 5 spd axel non ABS, and a 1985 honda accord SE-I 5 spd axel for the passenger side.
Old May 15, 2006 | 12:16 PM
Contender25
Guest
Posts: n/a
BTW, if you buy it from hmotors it SHOULD come with the shaft and bolts at least..
Old May 15, 2006 | 01:13 PM
Tippyman's Avatar
Default Re: (Contender25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Contender25 &raquo;</TD></TR><TR><TD CLASS="quote">ANY HUBS besides std and hf will work, that means ONLY the dx/lx/si/ex hubs will WORK. You can use 90/91 drivers side acura integra 5 spd axel non ABS, and a 1985 honda accord SE-I 5 spd axel for the passenger side. </TD></TR></TABLE>
Are those the only two axles I can use? I was planning on going to the junkyard to get the axles, but now I'm thinking that I can just go to Advance Autoparts (or is it Autozone?) and get those lifetime guarantee axles. If they break, I'll just get new ones for free!
So, since I'm gonna buy them new, what are the ideal axles to use with the DOHC ZC tranny and Civic DX hubs?
Old May 15, 2006 | 01:18 PM
jlicrx's Avatar
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
So, since I'm gonna buy them new, what are the ideal axles to use with the DOHC ZC tranny and Civic DX hubs?</TD></TR></TABLE>
90-93 Integra axles - one left and one right (the left has longer splines where it goes into intermediate shaft) - remove the dust rings from the axles and hubs
Old May 15, 2006 | 01:21 PM
Tippyman's Avatar
Default Re: (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">90-93 Integra axles - one left and one right (the left has longer splines where it goes into intermediate shaft) - remove the dust rings from the axles and hubs</TD></TR></TABLE>
So remove the dust rings fro the DX hub I am getting, and the axles?
Also, does it matter which Integra model I get them from? Which trim level is preferable?
And does anyone know if it is A.A. Parts or Autozone that has the lifetime guarantee axles?
Old May 15, 2006 | 01:28 PM
jlicrx's Avatar
yes, remove the dust rings from both - all 90-93 Integra axles are the same - i believe Advance and Autozone both have lifetime warranty
Old May 15, 2006 | 01:32 PM
Tippyman's Avatar
So I need these, correct:
Left: http://www.partsamerica.com/Pr...set=A
Right: http://www.partsamerica.com/Pr...set=A
Old May 15, 2006 | 01:35 PM
jlicrx's Avatar
those are for ABS - get the ones without ABS - should be about $15 each less
Old May 15, 2006 | 01:42 PM
Tippyman's Avatar
Those correct?
Old May 15, 2006 | 01:43 PM
jlicrx's Avatar
those are correct ones
Old May 15, 2006 | 01:45 PM
Tippyman's Avatar
Cool! Thanks alot, you've been very helpful!
I e-mailed HMO to see if it comes with the intermedate shaft.
Once I get some $$$ together, I'll let you guys know how it went!
Old May 15, 2006 | 01:52 PM
jlicrx's Avatar
do you have cores? they want $60 each for core for non-ABS - no core charge on ABS
Old May 15, 2006 | 01:53 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">do you have cores? they want $60 each for core for non-ABS - no core charge on ABS</TD></TR></TABLE>
What? Those axles aren't complete? What are cores?
Old May 15, 2006 | 01:57 PM
jlicrx's Avatar
cores are the old axles needed for trade-in - they are then rebuilt - most of the time you can just give them any old axles and they don't check to see if they are the matching ones
Old May 15, 2006 | 02:00 PM
Tippyman's Avatar
So should I just get new axles so there is no core charge?
Old May 15, 2006 | 02:01 PM
thenick's Avatar
Cores are the old ones you bring in. Kind of like a trade except your old axles are valued at a certain amount of money which will get discounted when you bring in your old axle.
Example:
new axle = $100
old axle/core= $50
so that means you pay $100 if you don't bring in your old axle and $50 if you do.
Old May 15, 2006 | 02:05 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">So should I just get new axles so there is no core charge?</TD></TR></TABLE>
the ones you linked to are all new axles - if you don't have cores, you would be money ahead to buy the ABS axles
Old May 15, 2006 | 02:07 PM
crxnj's Avatar
just get some from rockauto.com ...$54 brand new no core charge,,and the stuff comes quick..and i have a discount code to from my last order..pm me if you want it..
Old May 15, 2006 | 02:08 PM
Tippyman's Avatar
Default Re: (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">just get some from rockauto.com ...$54 brand new no core charge,,and the stuff comes quick..and i have a discount code to from my last order..pm me if you want it..</TD></TR></TABLE>
Thanks man! I'll check it out...
Old May 15, 2006 | 02:20 PM
Tippyman's Avatar
BTW: you have pm...
Old May 15, 2006 | 03:13 PM
Contender25
Guest
Posts: n/a
Jilicrx knows what he is talking about, he is the one that told me those axles. Truth is they both fit, but imo the you can get whatever you want, but if you buy them new, then you can have lifetime ones for free. It's not like its gonna overpower itself and break those axles, lol. I have called hmotors in the past about zc trannys before i ever had one and they said that yes it does come with the shaft and bolts i believe.
Old May 15, 2006 | 03:33 PM
ludesrv's Avatar
Just get an Si tranny. Shorter gears means better acceleration, and you can use your stock shafts.
