First time on M&H slicks...
Old May 15, 2006 | 02:15 AM
Astig's Avatar
Default First time on M&H slicks...
What can I expect? I've always ran on street tires, and this Wednesday, I'll be running on some M&H 22x8x13s via Lensos.
Start them at 10 PSi and go from there? Any particular break-in process? Feel any different going down the track?
N00b yes, but I'm just a little nervous!
Old May 15, 2006 | 03:50 AM
Zubaltec's Avatar
Default Re: First time on M&H slicks... (Astig)
Preload.
Get ready for the ride of your life. I remember the first time on slicks, what a difference.
Old May 15, 2006 | 04:06 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: First time on M&H slicks... (Zubaltec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zubaltec &raquo;</TD></TR><TR><TD CLASS="quote">Preload.
Get ready for the ride of your life. I remember the first time on slicks, what a difference.</TD></TR></TABLE>
he hee....yeah my first pass i didnt get enough heat in them and clicked off a 12.55 at 125 and probably travled 1700 feet down the 1/4 mile because i was all over the place. but it is fun. remember preload and youll be ok.
john you guys making atco?
Old May 15, 2006 | 04:17 AM
nasteboyii's Avatar
Slicks will definitely be a different feel
me and mikey both went out last weekend and learned on slicks at etown
preload and make sure u got enough boost built makes all the difference in the world
practice practice practice
dan
Old May 15, 2006 | 09:14 AM
Astig's Avatar
Default Re: First time on M&H slicks... (nasteboyii)
Oh no no no you guys misunderstood.
Talking about tire pressure, not turbo boost. LOL!
Old May 15, 2006 | 09:38 AM
nasteboyii's Avatar
yea what i ment by that was
if u run 10psi, at first with tire pressure, and it spins lower more, yes, but i was saying to make sure u are launching hard, make sure boost pressure is building to leave very hard, and id say start closer to 7psi, first tiime out for us, running mid6psi
good luck
d
Old May 15, 2006 | 10:18 AM
Mr. Badwrench
since my car doesnt make power down low, and bogged bad with them at 7 psi, it actually 60'd better with tire spin keeping the turbo in boost. the best 60' i got was a 1.73 with it spinning and 9.25 psi in the tires.
and we cannot say it enough, PRE LOAD. your final drive and axles will thank you for it.
Old May 15, 2006 | 10:53 AM
Zubaltec's Avatar
Default Re: First time on M&H slicks... (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">
Does a bear s**t in the woods?
You know we'll be there. This is what I live for.
Old May 15, 2006 | 10:57 AM
Mr. Badwrench
cool cool man ill see ya there!~ i have a goal of 135 mph now. we are gonna try to put some timming into it and see what we can do.
Old May 15, 2006 | 11:02 AM
Astig's Avatar
Uh... once again... I'm not talking about boost. I am non-turbo, but anyway.
Thanks guys!
Old May 15, 2006 | 11:06 AM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Astig &raquo;</TD></TR><TR><TD CLASS="quote">Uh... once again... I'm not talking about boost. I am non-turbo, but anyway.
Thanks guys!</TD></TR></TABLE>
well in that case, you will still need to wind it up pretty good, you may have to lower the pressure to around 7 ish. as john from m&h told me, start at like 9 and go down from there.
Old May 15, 2006 | 11:07 AM
nasteboyii's Avatar
ok well in that case that your not boosted, start at 10 psi, find a good rpm to launch at, id say up above 7k, and dump clutch preloadded, see if it bogs or spins, if it spins alittle thats good, if it bogs put more air in tire, or launch harder, and keep going at it
good luck
d
Old May 15, 2006 | 04:01 PM
josh green's Avatar
a lot of people do huge burn outs, now I dont know your compound but most manufacturers say that you only need a light burnout, and that greatly improves tire life.
Old May 15, 2006 | 05:13 PM
Mr.E.G.'s Avatar
what does preload mean?
Old May 15, 2006 | 05:22 PM
josh green's Avatar
letting the clutch out until it starts to grab. The your gears and everything are already pushing on each other so there is no "slapping" thus causing snapping. Not to mention faster mechanical reaction.
Old May 15, 2006 | 06:19 PM
SlicksMH's Avatar
John
M&H
Old May 15, 2006 | 06:58 PM
red cx's Avatar
Default Re: First time on M&H slicks... (SlicksMH)
If your launching on slicks for the first time remember three things
1- PRELOAD the trans
2- leave hard "manic status"
3- cross your fingers and toes
I rember my first ride on slicks, I thought I broke my neck
Old May 15, 2006 | 06:59 PM
b18c195's Avatar
lol i remember my first time with slicks.. scrared the **** out of me. I was like dammmmm my car is fast...
MindLess311
Sep 26, 2007 06:48 PM
steve96accord
May 12, 2006 09:17 PM
2kTeg
Sep 2, 2005 08:45 AM
PTR1
Aug 24, 2004 01:26 PM
dclsvtec
Jun 1, 2004 03:10 PM
