diffrences between z6 and y8 trannys?
Old May 14, 2006 | 09:28 PM
IVAN93EG's Avatar
Default diffrences between z6 and y8 trannys?
are the internals the same in the z6 and y8 trannys. is one better than the other for acceleration? are they geared the same?
Old May 14, 2006 | 09:59 PM
Red_ED8's Avatar
Default Re: diffrences between z6 and y8 trannys? (IVAN93EG)
I'm not sure about the internals or tranny but the Y8 has a higher compression then the Z6, thats why it's so popular to do a mini me (D16Z6 with D16Y8 head) setup. Sorry I couldn't help with the rest
Old May 14, 2006 | 10:06 PM
Red_ED8's Avatar
Sorry, I should probly read the whole thread before I post
Old May 14, 2006 | 10:07 PM
FalkenSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVAN93EG &raquo;</TD></TR><TR><TD CLASS="quote">are the internals the same in the z6 and y8 trannys. is one better than the other for acceleration? are they geared the same?</TD></TR></TABLE>
There is a small difference. I believe its fourth and fifth gear. So small you will NEVER notice it, the Y8 is slightly shorter. Also, the Y8 trannies have steel forks, which makes it stronger and can take more abuse than the Z6. If I had a choice, I would pick the y8. If not, then don't stress over it and get either one.
Old May 14, 2006 | 11:23 PM
kuja396's Avatar
I've had both a z6 and a y8 transmission and I couldn't tell a difference at all. I would get a y8 just because its probably going to have less miles on it. I have heard that the forks are stronger on the y8 as well.
radicaled434
Apr 26, 2008 12:49 PM
carlthecrx
Aug 14, 2007 03:18 PM
