Punched Cat
Old May 14, 2006 | 09:03 PM
Amused's Avatar
Default Punched Cat
CEL came on the other day, so I checked to code, and the ECU is throwing a 67, which means the Catalyst is malfunctioning. I even replaced the sencondary O2 sensor and reset the ECU, just to have the CEL come back on.
I plan on getting a new header and a 2.5 exhaust set up soon. As a temporary solution, would it be ok to punch my cat out? would I gain any performance from it? any cons? besides pollution will my ECU throw any more codes, or go into limp mode?
Old May 15, 2006 | 08:46 AM
cjames235's Avatar
Default Re: Punched Cat (Amused)
it may pick up a lil bit of power but it will smell like ***, pollute the air, and still cause a CEL from the secondary o2 sensor
Old May 15, 2006 | 10:56 AM
white rocket's Avatar
Nice thread title . I was fearing that this was an animal cruelity post.
Old May 15, 2006 | 12:47 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: (white rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket &raquo;</TD></TR><TR><TD CLASS="quote">Nice thread title </TD></TR></TABLE>
I thought the same thing. I knew what it was about, but I pictured something a lot different!
Old May 15, 2006 | 02:02 PM
Amused's Avatar
so it will not affect the way the car runs, meaning that the ECU will not throw anymore codes besides the one for the secondary 02 sensor. when you mean smells bad, will it smell like rotten eggs or just rich?
Old May 15, 2006 | 07:52 PM
ITR#132's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Amused &raquo;</TD></TR><TR><TD CLASS="quote">CEL came on the other day, so I checked to code, and the ECU is throwing a 67, which means the Catalyst is malfunctioning. I even replaced the sencondary O2 sensor and reset the ECU, just to have the CEL come back on.
I plan on getting a new header and a 2.5 exhaust set up soon. As a temporary solution, would it be ok to punch my cat out? would I gain any performance from it? any cons? besides pollution will my ECU throw any more codes, or go into limp mode?</TD></TR></TABLE>
Punching out your cat is not a temporary solution because it wont clear your CEL.
98greensi
Aug 29, 2009 08:23 AM
slowB20ej8
Apr 11, 2008 07:18 PM
guamie
Jul 17, 2007 08:14 AM
D3U1LT
Sep 20, 2004 05:24 AM
