type r rear sway bar
Old May 14, 2006 | 08:12 PM
diagnostic's Avatar
Default type r rear sway bar
I hear allot about subframe tearout with the itr rear sway bar. but it seems that allot of the tearout i see is on civics.
what about on the 94-97 integra's? do you still need the subframe reinforcements for it? or is it safe to install without?
Old May 14, 2006 | 08:17 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: type r rear sway bar (diagnostic)
I would install it still, no matter what I heard. I used the Beaks kit on mine.
Old May 14, 2006 | 08:21 PM
diagnostic's Avatar
Default Re: type r rear sway bar (00IntegrAllmotoR)
so you used the beaks reinforcement kit on your dc with the itr sway bar?
i guess better safe then sorry.
so its probably not a good idea to just install it without a kit.
Old May 14, 2006 | 09:30 PM
BlueIntegraBoy's Avatar
The tearouts happen mainly on 96-00 Civics due to the location for the sway bar holes (more towards the wheel than the LCA bolt). Also the subframe on those Civics are thin. I am running an ASR kit on my EG with the ITR sway. I love it. But, yes, more safe than sorry.
Old May 14, 2006 | 09:31 PM
bong_yan's Avatar
beaks???!! thats a no no!!! i seen some pics out there where the subframe tore out because of the beaks kit.....i wouldn't put that on......go with the ASR subframe reinforcement kit or the comp-tech one.....i got that ASR on mines and i been going through too many corners and still no problem....do some research before you settle with just anything....good luck
Old May 15, 2006 | 03:39 AM
VTteg's Avatar
Default Re: type r rear sway bar (bong_yan)
I would contact BSQ on here and buy his reinforcement kit. It's only about $20 and does the job perfectly. Haven't heard of anybody complain about damaged subframes while using his kit.
Old May 15, 2006 | 07:55 AM
diagnostic's Avatar
it looks like the asr or the comptech are really good kits.b does anyone know of any other kits available? id like to look at all the options before buying.
Old May 15, 2006 | 02:01 PM
HT Black OPs
I have had no problems with mine, and I have a 2 inch drop on my car.
You can see the Beaks kit kind of in this pic.
BTW: I used grade 8 blots instead of the ones provided by Beaks, just to be safe.
Old May 15, 2006 | 02:20 PM
mrdeadman's Avatar
They let me pick
beaks kit.
Old May 16, 2006 | 06:10 PM
diagnostic's Avatar
Default Re: type r rear sway bar (mrdeadman)
so from what i gather, the beaks kit is fine. , but the comptech is evan safer. so i COULD use the beaks kit, or the asr.comptech kits if i wanna be 110% sure.
someone said before the beaks kit was a no-no. why is that? what are the risks with this kit?
Old May 16, 2006 | 06:32 PM
mrdeadman's Avatar
They let me pick
i did a lot of research before i bought my beaks kit, and it was a great choice, im really happy with it and i know a bunch of other people are as well, there are countless topics like this where it is covered, just search and you will find them.
Old May 16, 2006 | 06:43 PM
magicaltrout's Avatar
pardon my intrusion, but i was thinking about getting sway bars upgraded as well. to those that have installed a subframe reinforcement kit; is that bolt there notorious for rusting and freezing like the bolt at the lower shock mount? of course there's no guarantee that it won't be but i would just like to know if the majority of the case is... that way i know if i should buy an extra saw blade and bolts. thanks.
Old May 16, 2006 | 08:13 PM
blkb18's Avatar
Default Re: (magicaltrout)
its common for the bolts to seize in the bushings, especially on high mileage northern cars. Plan on bushing and possible bolt replacement.
Old May 16, 2006 | 09:11 PM
Lauj87's Avatar
now lets see some pics of some torn subframe's :-D
Old May 16, 2006 | 10:53 PM
ctownintegra's Avatar
I installed my ITR Sway today with the Beaks kit on my 95 GSR.
This will be the best mod you do for the money.
Be safe and get the kit rather than having to weld new sheetmetal to your subframe.
Old May 17, 2006 | 01:45 AM
integra3586's Avatar
Default Re: (Lauj87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lauj87 &raquo;</TD></TR><TR><TD CLASS="quote">now lets see some pics of some torn subframe's :-D</TD></TR></TABLE>
yeah!!!!!!!!!!!!!!!!!!!
ive searched but couldnt find anything. searching&gt;me
Old May 17, 2006 | 04:51 AM
mrdeadman's Avatar
They let me pick
Default Re: (B18B-SC)
integras pics with torn subframe are pretty rare, you can find civic ones easier.
Old May 17, 2006 | 06:06 AM
4potnick's Avatar
Default Re: (mrdeadman)
when you say civic. you mean 96-00 and not so much 92-95
Old May 17, 2006 | 07:06 AM
LsHoney84's Avatar
Default Re: (4potnick)
i recall someone saying that with the asr kit you dont have to drill/enlarge any holes. Its a direct bolt on, whereas the other ones you have to enlarge the holes that are already there.
Feel free to correct me if im wrong.
kenzo42
Oct 28, 2011 04:08 PM
r1ch1e
Oct 14, 2006 06:42 AM
zeroz
May 9, 2005 12:12 AM
yoda888
Feb 6, 2004 10:59 AM
dgdarien
10
Mar 30, 2003 01:09 PM
