Whats your shifter setup?
What is everyone using as their shifter?
Right now I have a skunk, but it hits my exhaust pipe so I want to change it out.
I'm thinkin just stock, just wondering if anyone else has any opinions to share?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ »</TD></TR><TR><TD CLASS="quote">Stock ITR shifter, linkage, and ****.
Minus the **** for me. The type r lever is the best that you can get IMO. It's different form a gsr, and it provides the most positive feel over anything aftermarket. The "short shifters" ruin your tranny if you bang gears, they will actually shift too fast for the synchros and thats why they grind. The type r lever will not grind your gear box at all as long as you are shifting correctly, you can go as fast as you want. I love my lever.
</TD></TR></TABLE>Minus the **** for me. The type r lever is the best that you can get IMO. It's different form a gsr, and it provides the most positive feel over anything aftermarket. The "short shifters" ruin your tranny if you bang gears, they will actually shift too fast for the synchros and thats why they grind. The type r lever will not grind your gear box at all as long as you are shifting correctly, you can go as fast as you want. I love my lever.
It was 135 dollars and it was one of the best upgrades I did. http://www.forbiddenmotorsport...elude
i <3 my fastline shifter. if your S2 shifter hits the exhaust, you'll definitely have to move it to use the fastline one, but it's well worth it. stock throw, positive feel, and it's nearly impossible to misshift. you can pivot the 'S' bend so that it's mere inches from the wheel. shifts are quick and accurate. it's billet steel, so the threads won't strip like some of the cheap Al ebay jobs, and the weight helps for smooth shifting, even with the stock ****.
