need help no spark
Old May 14, 2006 | 05:16 PM
89sicivic's Avatar
Default need help no spark
after doing a mini me swap z6 head on a zc bottom end i took the car around the block and the motor started to misfire really bad and then it wouldn't rev past around 2k-2.5k then all the sudden it would shoot off then the rpms would just drop clear done....so after a fun time getting it home i check for spark and there was hardly any spark..and my car was running real rich cause of hardly any spark....what all should i check w/ this matter?
Old May 14, 2006 | 10:45 PM
dxtosirex's Avatar
Default Re: need help no spark (89sicivic)
Since you did a minime head swap you should double check your timing on the motor and also see if you have any wire mess up or a bad ground.
nutball72
Apr 27, 2006 10:59 AM
killer6993
12
Mar 15, 2005 10:05 AM
Gumbey75
26
Feb 10, 2005 04:35 PM
importeclipsegst
Apr 16, 2004 04:52 PM
[626]95-GSR
Feb 14, 2002 03:11 PM
