95 teg gsr with 215,000 on odometer..... need rebuild
Old May 14, 2006 | 04:42 PM
boehmdw97's Avatar
Default 95 teg gsr with 215,000 on odometer..... need rebuild
i have a 95 gsr with 215,000 on the odometer. got a leak down test/ comp test and it only read 135 across the board. car still runs ok but when cold, you can here the motor noise of pistons/ valves bad. had valves adjusted, new waterpump/timing belt installed..... should I rebuild, do a crvtec swap, or put a newer gsr motor back in? i only have about 3000 to spend. please help?
Old May 14, 2006 | 05:52 PM
lVlemphizStylez's Avatar
Default Re: 95 teg gsr with 215,000 on odometer..... need rebuild (boehmdw97)
buy a gsr long block for a lil more than half of that....1800 from hmotors...and call it a day
gp01fb
Apr 19, 2006 04:44 PM
1995redGS-R
Jul 18, 2005 02:39 PM
