Stock rates
What are the stock spring rates for CRX Si?
I've been looking into aftermarket suspension, and as far as springs go I see a lot of different things. For example, Tien SS's have something like 140 lb/in rear and 269 lb/in front. That doesn't seem very stiff to me. Then I was reading this guy's EF website and he was saying a heavy front bias for spring rates was the preserve the stock understeering tendency, he reccomended something like 500 f/r which is way stiffer. Just wondering what the real story is because that's a huge difference, and I was also wondering how stiff the stock ones are by comparison.
Just to give you an idea here, this is some info I collected some time ago doing my research for my current coilovers:
96-00 EX _________165F/80R (P/P)
LS/GS/RS integras__212/117
GS-R - ___________200F/95R (P/P)
99-00 Si (EM1) - ___201F/99.8R (P/P)
CTR - ____________240/240 (L/P)
97, 00-01 ITR - ____250F/250R (L/P)
Where P=progressive and L=linear
This is all info I gathered here on HT so don't blame me if it's off. I have 320/250 ground control coilovers and it's pretty comfortable for DD, but a little too soft for me. I would have gone with a 400/350 or something like that. I am going to guess and say the CRX si is in the 120/60 range... **just a guess** I used to have an EF hatch so I can't be that far off
And make sure if you go with stiff spring rates, that your bushings are in good condition because a stiffer suspension is going to bring up more stress on the bushings, causing them to wear off quickly. My hatch needed new bushings badly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg9 »</TD></TR><TR><TD CLASS="quote">Just to give you an idea here, this is some info I collected some time ago doing my research for my current coilovers:
Are stock Civic EX springs really that soft?!?!
Yeah some of those numbers are indeed off. GS-R springs are identical to RS/LS/GS/SE springs - the LS rates are correct, I don't know where they got the "GS-R" rates. ITR springs (you forgot '98, the best year
) are 246F/13x-246R progressive (the lower number is somewhere between 120-150, forget which). I dunno about the Civic rates.
</TD></TR></TABLE>Are stock Civic EX springs really that soft?!?!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White98LS »</TD></TR><TR><TD CLASS="quote">
) are 246F/13x-246R progressive (the lower number is somewhere between 120-150, forget which). I dunno about the Civic rates.</TD></TR></TABLE>
Yes, civic rates are awefully low. And regardless of trim (except for 99-00 si), they are all the same. At least 92-00. I had an ef hatch (1920 lbs) and that thing rolled rolled like a pig in turns, from experience, I would say they are way lower.
) are 246F/13x-246R progressive (the lower number is somewhere between 120-150, forget which). I dunno about the Civic rates.</TD></TR></TABLE>Yes, civic rates are awefully low. And regardless of trim (except for 99-00 si), they are all the same. At least 92-00. I had an ef hatch (1920 lbs) and that thing rolled rolled like a pig in turns, from experience, I would say they are way lower.
