S1 tranny wont shift into 5th or reverse (searched)
Old May 14, 2006 | 02:03 PM
C_I_V_I_C's Avatar
Default S1 tranny wont shift into 5th or reverse (searched)
well I dropped my B16 in, but had the linkage attached to the motor/trans. When I was lowering the motor in I forgot to move the linkage, so I lowered the motor onto the linkage. The linkage was bent on the end a little bit, so I straightened it out. But no luck, I spend a few hours trying to rebend the linkage to hit 5th and reverse, but no luck still.
The motor was in a different EF and shifted fine and everthing.
Old May 16, 2006 | 03:46 PM
boostedblkef's Avatar
Default Re: S1 tranny wont shift into 5th or reverse (C_I_V_I_C)
not sure of your question here you have already found your answer <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_I_V_I_C &raquo;</TD></TR><TR><TD CLASS="quote">well I dropped my B16 in, but had the linkage attached I lowered the motor onto the linkage. The linkage was bent on the end a little bit.</TD></TR></TABLE>
Old May 16, 2006 | 04:11 PM
smokey2.0's Avatar
Default Re: S1 tranny wont shift into 5th or reverse (pitbullracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pitbullracer &raquo;</TD></TR><TR><TD CLASS="quote">not sure of your question here you have already found your answer </TD></TR></TABLE>true!
Old May 16, 2006 | 04:36 PM
shoemaker617's Avatar
Try disconnecting the linkage from the shifter and manual shifting it into 5th/reverse. If shifts that way fine then you prolly gotta adjust your shift linkage some more.
Old May 20, 2006 | 11:14 PM
C_I_V_I_C's Avatar
sorry guys, no answer was found.
As for trying it with no linkage attached; I did and I don't think it is clicking into gear. It moves in the direction the gear should be but I don't think its engaging.
Old May 24, 2006 | 06:27 AM
JIP's Avatar
JIP
sounds like a bad shift fork.
Old May 24, 2006 | 08:57 PM
C_I_V_I_C's Avatar
Does that require removing the whole tranny from the car?
Old May 24, 2006 | 10:45 PM
dpaton's Avatar
Replacing the shift forks requires disassembly of the transmission, so yeah, it's got to come out.
Old May 25, 2006 | 07:51 AM
ALLMOTOR18's Avatar
Default Re: (dpaton)
I also had the problem with the 5th and reverse.. It was very difficult to go into 5th and would not go into reverse.. I took my tranny to get rebuilt and they said it was the shift fork.. It was replaced and everything was fine...
With the same tranny a few years later, I had the same problem with my 1st and 2nd gears so i took it to get torn down and checked out... they said everything looked good so I put the tranny back in and after bending the shift linkage to the correct position the problem was gone...
Try swapping out the shift linkage with a known good linkage and if it doesnt fix that take it to get rebuilt and if it needs to be rebuilt, you might as well throw in a 4.785 FD and Quaife.....
rjc89sir
Sep 17, 2007 02:15 AM
spiderhatch
Apr 27, 2007 02:28 PM
whiteguyndahood
Jul 28, 2006 08:27 AM
J4k3
11
Feb 20, 2006 05:46 PM
atsyuo
Aug 24, 2005 11:43 AM
