questions about putting in a B16a2
so i'm new to the whole car world and i just bought my friends 94 eg shell and soon to get a complete b16a swap what do i else do i need besides besides the swap to insure everything goes smoothly and i can get it all done that day?
also what motor mount kit should i use?
thanks for any advice i greatly appreciate it
well if ur going to put a b16a2 into your eg you cant use the engine harness (if it comes with one) and you cant use the distributor because all that is obd-2 and ur car is obd1
i put a obd2 gsr motor into my eg and i ran into the same problems.......but what i did with the distributor was change the clips to obd1 so i didnt have the buy an obd1 distributor
for the mounts you can use any 94+ aucra integra stock mounts or you can get hasport aftermarket mounts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JordanFostersSN »</TD></TR><TR><TD CLASS="quote">so if i get a b16a1 then i can just drop the motor straight in? no problems</TD></TR></TABLE>
No, because a B16A1 or a 1st-gen JDM B16A is pre-OBD and comes with different mounts, shift linkage, and a cable-clutch transmission. Not to mention an engine manufactured earlier than the chassis is illegal for emissions in many states.
What you need is either a 2nd-gen JDM B16A or a B16A3.
Please use the search and the FAQs; this has been covered countless times.
killabs
Mar 26, 2009 02:46 PM
eg9-civic
Jan 5, 2008 01:20 PM
GummyBeng
Feb 12, 2003 02:17 PM
