Taking off 99-00 Civic Si Wiring Harness?
Old May 14, 2006 | 12:18 PM
Flava's Avatar
Default Taking off 99-00 Civic Si Wiring Harness?
How do you take it off? And where/what does it look like? Need help for a friend asap.
Old May 14, 2006 | 12:22 PM
professor poon's Avatar
Default Re: Taking off 99-00 Civic Si Wiring Harness? (dingy)
unplug ECU, carefully pull the ECU plugs (3 of them) through the hole in the firewall, then disconnect both of the main plugs from the chassis to the harness (1 on each side of the engine bay). Then basically just start disconnecting plugs till everything is off. That should be right, but I'm just going from memory..
Old May 14, 2006 | 12:24 PM
Flava's Avatar
Default Re: Taking off 99-00 Civic Si Wiring Harness? (professor poon)
Forgot to add, the motor is already out of the car and unplugged from ECU. He just doesn't know what it looks like or how to unplug it from the motor. Is it just clips?
Old May 14, 2006 | 12:27 PM
it's various types of plugs. If it's on the motor out of the car, then it's just common sense. It looks like a confusing black spiderweb of wires with plugs/clips that connect to the motor in dozens of places. It's EZ.
Old May 14, 2006 | 12:28 PM
That is what it looks like once disconnected
Old May 14, 2006 | 12:29 PM
that's not the right harness, but it'll give you an idea of the layout and ****.
Old May 18, 2006 | 12:11 PM
Flava's Avatar
Default Re: (professor poon)
Is the whole wiring harness ALL the wired on the engine? There's wire that are on the harness that go to like the dizzy that aren't plugs, what am I supposed to do about those?
Old May 18, 2006 | 12:26 PM
cua0's Avatar
unscrew them from the alternator/starter
thats the only place there should be a screwed on connection
tdo
Jul 18, 2009 01:07 PM
BOMBCRU
Apr 14, 2005 09:59 AM
NJcoupe
Dec 24, 2004 10:47 AM
B18ek
Nov 27, 2004 07:39 AM
navin
25
Jul 18, 2003 08:39 PM
