Oil leakage after Ignition coil installed
Old May 14, 2006 | 11:44 AM
hussar7's Avatar
Default Oil leakage after Ignition coil installed
Greetings-
I'm the owner of a '95 Del Sol, the best car I've ever owned. 2 weeks ago, it left me sitting at work, engine turned over but wouldn't start. Called the wife and wnet back to work Monday with the wife's car and had AAA tow it to my local Honda Dealer. They finally got around to repairing it on a Wednesday, told me my ignition coil was bad and it needed replacing, no problem. Paid for it Wednesday but didn't pick it up until Friday, called the dealer shuttle, picked it up and dropped it off at work when the wife could take me to pick it up SUnday and we could drive both cars home. Picked it up Sunday, took it home, no problems.
Drove the car to work Monday, thought it was great to have my old friend back after a week of driving a Mazda. Monday night, started car, noticed it making a new sound, sounded like an exhaust problem, between 2000 and 4000 rpm, the baby would rumble and sound real throaty. Drove it home and as I turned into my driveway, it stalled. Started up with a terrible noise and had to gun it to get it up the drive.
Well, to finally end this long story, I had it retowed to the dealer. What they informed me was that It was out of oil and the engine seized up. Now, I check the oil monthly because I use approx. a quart a month of oil (It has 144000 miles on it). SO I know I didn't let it go dry.
My question is, could anything done while installing the ignition coil cause this sudden oil loss and if not, anyone have any other ideas? Thx -RIC-
Old May 14, 2006 | 11:47 AM
fmrprojects's Avatar
Default Re: Oil leakage after Ignition coil installed (hussar7)
when you remove a distributor oil does leak out but not a lot. maybe the timing is way off when they reinstalled it and you have a power loss.
Old May 14, 2006 | 01:07 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Oil leakage after Ignition coil installed (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">when you remove a distributor oil does leak out but not a lot. maybe the timing is way off when they reinstalled it and you have a power loss.</TD></TR></TABLE>
You don't have to take the distributor off to change the coil and you don't alter the timing when you change the coil. Oil loss has nothing to do with the coil being changed, unfortunately, so the demise of this engine is going to be chalked up to oversight on the owner's part and nothing else.
RIP.
$92CB7$
Jul 13, 2015 01:22 PM
JoHA
Jun 9, 2008 07:50 AM
1Point8DC2
Aug 20, 2007 12:30 PM
Stealthman80
Jul 24, 2007 05:39 PM
leecappella
May 17, 2006 03:44 AM
