Steering shakes when braking
Old May 14, 2006 | 09:59 AM
DBoost's Avatar
Default Steering shakes when braking
Well a few weeks ago I started feeling that my steering shaked while braking, first I thought that was due to my rotors but after a closer inspection I noticed this:
Correct me if Im wrong but thats a ball joint right?
What do I have to replace so that the shaking is gone, that arm or the hub assembly?
Sorry I dont know the name of the steering parts
Thanks
Old May 14, 2006 | 10:03 AM
s2kdre's Avatar
Default Re: Steering shakes when braking (DBoost)
thas an outer tie rod, thats not gonna get rid of shaking, im sure ur front end is tight, my car has 200k miles on it and i've never had to replace front end parts yet.
Old May 14, 2006 | 10:16 AM
EvenStar's Avatar
Dud u take that ball joint out of the socket? Or was it like that when u first took out the wheels?
Old May 14, 2006 | 10:29 AM
gsr dood's Avatar
ur lucky ur still alive.
Old May 14, 2006 | 10:30 AM
DBoost's Avatar
Default Re: Steering shakes when braking (jdmhonda)
Well maybe this picture can explain a little better:
When I lifted the car and the tire was still on, it felt loose and I saw movement where the tie rod connects with the hub
Old May 14, 2006 | 10:31 AM
DBoost's Avatar
Default Re: (EvenStar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvenStar &raquo;</TD></TR><TR><TD CLASS="quote">Dud u take that ball joint out of the socket? Or was it like that when u first took out the wheels?</TD></TR></TABLE>
Yes, I did that first
Old May 14, 2006 | 12:37 PM
InfamousDC2FI's Avatar
Default Re: (DBoost)
ya your missing a nut....
Old May 14, 2006 | 12:43 PM
Default Re: (InfamousDC2FI)
i would get a new tie rod end if I was you....then go get your car to an alignment shop.
number 13 or 16 in the diagram
http://www.barancoacuraparts.c...ch=no
Old May 14, 2006 | 12:49 PM
jay_96teg's Avatar
you people are ******* idiots
Old May 14, 2006 | 12:56 PM
b20integrapower's Avatar
Default Re: (jay_96teg)
why not just go get the nut? why would you have to replace the whole thing?
Old May 14, 2006 | 01:41 PM
efcivic757's Avatar
I have no idea what your pics are showing, with your explanations, but your first pic, your tie rod end is not in. I hope you actually took that out before the pic. If you had a nut on there, and there is still movement, replace tie rod ends. Yes they do go bad. I just replaced both of mine. With you wheel still on, jack the car up and push and pull on the wheel and see where the play is. If the whole tie rod moves when you push from left to right, it is inner tie rod end. If it doesn't and there is play, outers. If you have ply when you push up and down then could be a ball joint.
Old May 14, 2006 | 01:46 PM
dc2legend's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay_96teg &raquo;</TD></TR><TR><TD CLASS="quote">you people are ******* idiots
HOLY ****!!!!
That ******* just solved his problem. KILL YOURSELF!!!
Old May 14, 2006 | 02:35 PM
DBoost's Avatar
Default Re: (dc2legend)
I guess I did not explain the issue really good, but ended up going to vatozone and got the tie rod, and problem solved, no more shaking....taking it to alignment first thing tomorrow morning
Old May 14, 2006 | 06:25 PM
pat.ter.rick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">im sure ur front end is tight, my car has 200k miles on it and i've never had to replace front end parts yet.</TD></TR></TABLE>
don't jinx yourself now!
Annihilator
Feb 9, 2011 12:03 AM
Hey_T
Suspension & Brakes
Jan 9, 2010 09:04 PM
hondazccivic
19
Oct 16, 2008 08:20 PM
Black R
Jul 29, 2004 02:54 PM
