wiring slim fan
Old May 14, 2006 | 09:55 AM
BOOSTED_JDM_DB8's Avatar
Default wiring slim fan
on the slim fan it has a red wire and a black ground wire
on the stock integra fan it has blue and black wire
do i wire the blue wire to the red wire together and leave black wire as ground?
or
do i just wire blue to the red and black to black wire together?
if you you instructions that will be great
Old May 14, 2006 | 10:17 AM
no2unenolife's Avatar
Hey, you can connect them any way you want.
The only difference is the way you want the fan to move. One way will be a pusher and the other will be a puller.
Let me know if you have any more questions.
Also, just connect them in pairs. and switching the polarities will switch the pusher/puller style.
Old May 14, 2006 | 10:30 AM
gsr dood's Avatar
Default Re: (no2unenolife)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no2unenolife &raquo;</TD></TR><TR><TD CLASS="quote">Hey, you can connect them any way you want.
Let me know if you have any more questions.</TD></TR></TABLE>
Old May 14, 2006 | 10:34 AM
Default Re: (gsr dood)
whats the diffrence from pusher and puller stlye?
how do i wire to get pusher or puller style?
Old May 14, 2006 | 02:40 PM
SargentNg's Avatar
Default Re: wiring slim fan (integraXgsr)
Black should be ground. If you're mounting it in the stock fan location, connect the black wires together and the red and blue together. Stock fan is a puller, it pulls air through the radiator. If you mount your fan in front of the radiator, you have to swap the wires and flip the blades around so your fan pushes air through the radiator. After you install it, test it to make sure the air flows in the correct direction.
Old May 14, 2006 | 02:43 PM
Danziver's Avatar
Default Re: wiring slim fan (SargentNg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SargentNg &raquo;</TD></TR><TR><TD CLASS="quote"> flip the blades around so your fan pushes air through the radiator. </TD></TR></TABLE>
Is it really necessary to flip the blades around?
Old May 14, 2006 | 03:03 PM
Sam92Teg's Avatar
Default Re: wiring slim fan (Danziver)
Years ago I actually bought a universal fan from the zone or Advance auto parts and it came as a pusher, so I had to flip the fan blade to use as a puller like stock. I don't know if other brands of fans need to be flipped or not, I think it depends on the fan design and the instructions included.
There is a vendor in the performance forum that sells electric fans for cheap, I have already purchased one and I will buy another soon. They are much more solid than the ones at the auto parts stores that are weak and flimsy. When you mount the flimsy fans to the radiator, they bend over time and start to rub on themselves or the radiator. Make sure to get a fan that has some rigidity built into the fan cage.
Old May 14, 2006 | 03:12 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: wiring slim fan (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danziver &raquo;</TD></TR><TR><TD CLASS="quote">Is it really necessary to flip the blades around?</TD></TR></TABLE>
Yes it is, said so on the instructions I got from B18bturbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraXgsr &raquo;</TD></TR><TR><TD CLASS="quote">whats the diffrence from pusher and puller stlye?
how do i wire to get pusher or puller style?</TD></TR></TABLE>
This is pusher, wire the fans so the black(fan) goes to pink(car) and the blue(fan) goes to black(car). If that makes sinse.
Old May 14, 2006 | 04:31 PM
importdude2000's Avatar
Default Re: wiring slim fan (00IntegrAllmotoR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">
u can mount a pusher on ac condensor?
will that work?
Old May 14, 2006 | 04:38 PM
Dartanian's Avatar
I didn't switch the blades on my pusher fans. They work just fine, so it might just be depending on what fan you use.
Old May 14, 2006 | 05:35 PM
Danziver's Avatar
Default Re: wiring slim fan (Das Schmoo)
Yeah, i never did either and mine worked fine. I just switched the wires.
Lsweez
Jul 7, 2007 07:32 PM
IIVIIoOkY
May 1, 2007 01:33 AM
FMIDRC Racer
Aug 27, 2005 12:22 PM
coupon
Jul 21, 2005 07:16 PM
billyhoe
Jan 8, 2005 06:28 AM
