clutch / slave cylinder...need some help
Old May 14, 2006 | 07:43 AM
flatblackintegragsr's Avatar
Default clutch / slave cylinder...need some help
94 GSR
the rpms drop really low when i push the clutch in, and occasionally, the clutch will lose its hydraulic pressure (which is really strange because i recently replaced the master cylinder and bled the clutch out.... and it kind of takes a second to be able to engage in 1st gear
a friend i know said it could be something with the slave cylinder??...what should i do...replace it perhaps?
if i need to be more precise, let me know (i tried)
any help is greatly appreciated...thanks
Old May 14, 2006 | 08:50 AM
mattcivic's Avatar
Default Re: clutch / slave cylinder...need some help (flatblackintegragsr)
ive always just replaced the master and slave at the same time on any car i drive. the added presure on the sytem will generally make the old part u didnt change go out soon after the first one is put in. ya get a new one i think they are like $60 bucks from honda. im not saying this will fix the prob i just always do them at the same time its like having shitty breaks and changing just the pads to find out your rotors are warped as well. GL
Old May 14, 2006 | 09:37 AM
Danziver's Avatar
Default Re: clutch / slave cylinder...need some help (mattcivic)
I just changed my master and slave cylinders and changing them was the easy part. Bleeding the system was a PITA.
Old May 14, 2006 | 10:44 AM
Default Re: clutch / slave cylinder...need some help (Danziver)
thanks ..i guess im buyin a new slave cylinder.....are there upgrades? should i get one or just stick to OEM?
Old May 14, 2006 | 05:51 PM
mattcivic's Avatar
OEM
Old May 14, 2006 | 06:06 PM
__oversea's Avatar
i dont think there is upgrade one..lol stick with Honda OEM.
Old May 17, 2006 | 03:26 PM
Default Re: clutch / slave cylinder...need some help (Last For One)
aight players
madeinchina
Transmission & Drivetrain
May 16, 2011 12:38 PM
sibious
Jun 13, 2008 03:53 PM
96WhiteOnBlack
Mar 26, 2007 07:15 AM
mdj_ge
Dec 3, 2004 06:45 AM
dragon_rev
Mar 27, 2004 03:21 PM
