Why did my car die?
Old Apr 11, 2002 | 09:56 AM
N24RE's Avatar
Default Why did my car die?
Hey Gang,
I was driving my car today and at the first stop light I came to and stopped the idle dropped way down, and in a few seconds it just died. I turned the key over and it fired right up. I have noticed the idle sometimes goes very low, low enough to cause the battery light to come on, but it has never died on me till today.
It's a 2001 with 17k miles...and it's bone stock ?
I would like to know what it is...so I can take it to the dealer knowing what is wrong.
Thanks
[Modified by N24RE, 1:56 PM 4/11/2002]
Old Apr 11, 2002 | 09:57 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Why did my car die? (N24RE)
Hey Gang,
Thanks
Just take it to Crown and make them fix it. A bone-stock car shouldn't be doing that
Old Apr 11, 2002 | 09:58 AM
N24RE's Avatar
Default Re: Why did my car die? (itr009)
True.....I just would like to know what it is?
I have a roll abr and harnesses in the car...so they will **** I am sure and say it's not covered, BUT.....you are right it shouldn't be doing this.
I'll give them a call.....
Cheers'
Back in Black's Avatar
Rather OG
Are you the owner of a bone stock NBP R I've seen around town? Don't be paranoid, as I'm a fellow owner
Old Apr 11, 2002 | 10:01 AM
N24RE's Avatar
Default Re: Why did my car die? (darth vadeR)
Probably,
I haven't passsed another Black R in town...seen a couple of yellow ones. I don't drive it often......You probably see me near Wendover or Battleground mostly?
Old Apr 11, 2002 | 10:04 AM
Rather OG
Yep, you guessed it. I saw you one morning fairly early heading north on battleground near the Biscuitville.
BTW, I never drive mine which is why you've never seen it. It actually looks more like a Special Edition
Old Apr 11, 2002 | 10:12 AM
N24RE's Avatar
cool.....no problem in that. I usually only drive it to the track or on the weekends. I did daily it for about 6 months when I first got it, I just drive my truck now.
You should come by my shop sometime
http://www.sportauto.cc
Old Apr 11, 2002 | 10:21 AM
ITRacer121's Avatar
Hey I live in TX is it cool if I come too?
If so I'll be there tommarow to test drive som of those honey's!!j/k
Old Apr 11, 2002 | 10:23 AM
N24RE's Avatar
Default Re: Why did my car die? (ITRacer121)
I'll meet you at the airport...when are you arriving?
Old Apr 11, 2002 | 10:25 AM
ITRacer121's Avatar
I didnt even post what I wanted to say about the problem I was drooling soo much!
this happened to my friend and He went to the dealer and told him to F-off b/c he had a cold air on his but he just went to auto zone and got this stuff (liquid wrench maybe ) and sprayed it into the throttle body until the motor died then sprayed a little more after death of car, waited 3 minutes and the car fired right up and the low RPM dips stopped and havnt happend again
good luck
Old Apr 11, 2002 | 10:27 AM
N24RE's Avatar
wow....that is wacky...sounds like something is hanging in the throttle body maybe?
Thanks for the info!!!!
Old Apr 11, 2002 | 10:40 AM
Splat's Avatar
I'll be there Friday afternoon
Old Apr 11, 2002 | 10:43 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Simple.. it's a honda.
-Dave, who is driving with boost again.. F' honduh!
Willard's Avatar
track use = dist. cap wear.
My car changed a lot when I replaced the cap and rotor. (~27,000)
Will
Old Apr 11, 2002 | 10:45 AM
N24RE's Avatar
Default Re: Why did my car die? (Willard)
Hmm....very interesting...the cap has died....what acctually happened to it?
Thanks for any insight!
Old Apr 11, 2002 | 10:47 AM
N24RE's Avatar
I won't be there
BUT we will be open...have one of the guys show you around. I will be on my way to the track Friday!
Old Apr 11, 2002 | 10:49 AM
Willard's Avatar
it did not die... but funny idle/throttle pickup = me looking into the electrical system.
plugs = normal wear
wires = no issues
rotor = slight wear on the arc surface
cap = all 4 prongs showed wear/buildup
replace cap/rotor = just fine.
I did replace the air filter at the same time... so that may have had a part
Old Apr 11, 2002 | 11:05 AM
pleiades nutz's Avatar
WOW!!!! thats all I have to say.....How about I buy my next car from you. *drooling*
SJ, I'll send you those pics after i get off of work.....actually im thinkin about quittin you wanna hire me?? Sorry for the OT.
[Modified by nighthawkR618, 2:12 PM 4/11/2002]
Old Apr 11, 2002 | 11:07 AM
N24RE's Avatar
Interesting....I just replaced my air filter a few weeks ago...then this problem showed up....that wouldn't have anything to do with it?....or would it....
still confused!
Thanks guys
Old Apr 11, 2002 | 11:10 AM
IntegraT's Avatar
Dayum, I couldn't afford the spare tire for most of those cars.
Old Apr 11, 2002 | 11:11 AM
N24RE's Avatar
Default Re: Why did my car die? (nighthawkR618)
I'd love to sell a H-T member a car
what kind do you want...Ferrari or Lamborghini
We have an F50 and F40 arriving in a few days....should I hold one of those for you
Old Apr 11, 2002 | 11:13 AM
sackdz's Avatar
Hmm F50 or F40? I'll have to test drive them both before I can decide.
Willard's Avatar
mileage on the two newer cars?
how much of a deposit is required for a test drive? is a ITR sufficient?
Willis
Old Apr 11, 2002 | 11:14 AM
Ill tell you what, since Im in such a good mood today ill take both and lets go ahead and throw a an F355 in there while were at it, you take AMEX??......
Old Apr 11, 2002 | 11:18 AM
N24RE's Avatar
AMEX...that will work...would you like your F355 in Spider, GTB, or Targa?
