CEL CODE 10!PLEASE HELP!
Old May 13, 2006 | 10:34 PM
jetblack's Avatar
Default CEL CODE 10!PLEASE HELP!
I've got a code 10 on my ecu and the car (b16a2) is running very poorly. I've checked the voltage to the sensor and its fine at 5v, i've also checked the resistance of the sensor and it falls within normal values(2,100ohms at room temperature). Are there any other components that fall within a code 10? Anything else i can check?
It has been suggested that the next thing to do is replace the ecu Any one else got any ideas?
This all happened after i swapped throttle bodies, i've now swapped back to the standard one and reset the ecu but its still running badly and throwing a code, i have connected all the wires correctly by the way!
Any help apreciated!
Old May 16, 2006 | 02:26 AM
jetblack's Avatar
Default Re: CEL CODE 10!PLEASE HELP! (jetblack)
ttt
Old May 16, 2006 | 08:35 AM
axtran's Avatar
perhaps your IAT is dirty or damaged, remove it and take a look at it?
Old May 16, 2006 | 06:20 PM
ph0shizzle's Avatar
same exact thing with my car.. cept my CEL is off but comes on later sometimes. but when i turn off the car it goes off then comes bac again later on. iono whats wrong with it.. i already changed the sensor and checkd the wiring many times.
elips0id
Apr 16, 2005 08:30 AM
c for sea
12
Oct 22, 2004 04:52 PM
KiD Fr0m Da 516
Aug 2, 2004 06:36 AM
B00ST2nR
Sep 16, 2002 05:06 PM
