Frame/car question
Old May 13, 2006 | 07:28 PM
jaymua's Avatar
Default Car opinion
I was looking at a teg and heres the link:
http://www.g2ic.com/forums/showthread.php?t=146359
where the driver side headlight is, on top of the headlight assembly the frame is bent a little. is the frame fixable? (answer this)
The car seems to crank good but all the noise when its cranking is coming from the distributor. would i need to install a new dist.?
the interior is not mint either the driver seat is torn some. and grease seems to be accumulating by the engine code.
Is this car worth fixing it up and making it a daily driver? tell me what you think. Thanks
Modified by jaymua at 6:59 AM 5/14/2006
Modified by jaymua at 7:09 PM 5/20/2006
Old May 14, 2006 | 04:57 AM
jaymua's Avatar
ttt
Old May 14, 2006 | 05:44 AM
mr.beeks's Avatar
Default Re: (jaymua)
that car is a steal....
damm I just gave away a driver seat and a black driver side fender..
but still have a distributor and a set of headlights.
grease around the engine code is a typical leak on the the cam plug.
some TLC will do for this car.
Old May 14, 2006 | 06:00 AM
jaymua's Avatar
thanks
any other tips?
Modified by jaymua at 7:42 AM 5/14/2006
Old May 14, 2006 | 06:56 AM
mr.beeks's Avatar
get rid of all the stuff that you dont need..
power steering
ac unit and lines
cruise control
check for any other leaks and look at the cams to see how much build up is there...
Old May 14, 2006 | 11:54 AM
jaymua's Avatar
bump
Old May 14, 2006 | 06:37 PM
jaymua's Avatar
bump
Old May 20, 2006 | 06:07 PM
jaymua's Avatar
bump
Old May 21, 2006 | 04:27 AM
jaymua's Avatar
yttt
Old May 21, 2006 | 06:27 AM
jaymua's Avatar
opinions needed
Old May 27, 2006 | 10:03 AM
jaymua's Avatar
bump
beyond305
Nov 30, 2012 09:54 AM
ExVtec
Honda S2000
10
Jul 29, 2009 02:39 PM
soulrider4ever
Jul 26, 2007 05:59 PM
EF_LSVtec
Feb 20, 2003 05:46 PM
Back in Black
May 13, 2002 06:19 AM
