What are the symptoms of a failing cam chain tensioner?
Old May 13, 2006 | 06:32 PM
The_Head's Avatar
Default What are the symptoms of a failing cam chain tensioner?
So, I've read somewhere that the Japenese Inline fours start to have problems with their cam chain tensioners after around 15,000 miles. I was just wondering how you can tell when it is starting to fail.
I checked a parts site and those parts for my bike are all backordered
Old May 13, 2006 | 06:39 PM
p nut's Avatar
For Honda's, you can hear a rattle in the lower rpm's (~5k). It'll get louder and louder. I'm having this issue at 7k miles, so I'll be getting the APE manual tensioner.
Modified by P Nut at 9:16 PM 5/13/2006
Old May 13, 2006 | 06:42 PM
marmaladedad's Avatar
It was most noticeable in my bikes when decelerating with the throttle closed or partly closed.
I highly recommend APE manual versions. They require adjustment once a year (under normal conditions).
Old May 13, 2006 | 07:17 PM
The_Head's Avatar
Default Re: (marmaladeboy)
http://www.yamahazone.biz/tensioners.html
Thanks for the recommendation. I will definitely look into having this done over the winter
Old May 13, 2006 | 08:58 PM
The picture shows you the end of the CCT that puts pressure on the cam chain.
Don't forget to order a gasket too.
Tenacious T
Honda Motorcycles
May 21, 2007 10:39 PM
ryanbartholomew85
Honda Motorcycles
38
Jun 26, 2006 01:16 PM
lawrence79
Honda Motorcycles
Nov 8, 2005 07:30 PM
eViL-on-2-wh33ls
Honda Motorcycles
May 24, 2004 01:53 PM
ih8danoles
12
Mar 26, 2003 06:00 AM
