B18b, need to check plastigage clearance but sorta confused.
Old May 13, 2006 | 04:19 PM
unknown0001's Avatar
Default B18b, need to check plastigage clearance but sorta confused.
Hey guys, I'd like to check the clearance on my rod bearings today on the b18b1 motor.
At the shop I printed off from Mitchell On Demand, the engine rebuild specs.
it says that for the rod bearing clearance it should be:
standard - .0002in (.005mm)
service - .0004in (.010mm)
now when I look at the green plastigage package, it ranges from .001-.003in and .025-.076mm
now my question is this...if the service limit is .010mm, how am I to figure that out if the plastigage on the mm side reads the lowest of .025mm
I've search through threads and found some answers but can't figure this out.
Does anybody know if those standard and service limits are correct for a b18b integra engine??
please and thanks
Old May 14, 2006 | 07:53 AM
rk's Avatar
rk
Default Re: B18b, need to check plastigage clearance but sorta confused. (Mr.RHTuner)
up for a friend in need
Old May 14, 2006 | 08:06 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">At the shop I printed off from Mitchell On Demand, the engine rebuild specs.
now when I look at the green plastigage package, it ranges from .001-.003in and .025-.076mm </TD></TR></TABLE>
The clearances are 0.0008"-0.0015". Limit is 0.002".
Old May 14, 2006 | 08:52 AM
Default Re: B18b, need to check plastigage clearance but sorta confused. (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">The clearances are 0.0008"-0.0015". Limit is 0.002".</TD></TR></TABLE>
but what confuses me is the plastigage only ranges from .00X-.00X
where you said, that the clearance is .000X, there is one more zero there compared to what the plastigage paper lists
Old May 14, 2006 | 09:50 AM
b19coupe's Avatar
You don't need the clearances as tight as 0.0008". For most motors you should shoot for around 0.0015", which is right in the middle of the green plastigage scale. I run my motors between 0.0015" and 0.002". The specs you got from Mitchell are wrong, BTW.
Old May 14, 2006 | 12:43 PM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote"> The specs you got from Mitchell are wrong, BTW.</TD></TR></TABLE>
Theres a huge surprise.
Old May 14, 2006 | 01:03 PM
PLAN:B's Avatar
Default Re: B18b, need to check plastigage clearance but sorta confused. (Combustion Contraption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">You don't need the clearances as tight as 0.0008". For most motors you should shoot for around 0.0015", which is right in the middle of the green plastigage scale. I run my motors between 0.0015" and 0.002". The specs you got from Mitchell are wrong, BTW.</TD></TR></TABLE>
Just to back it up, he is very correct
LS-turboner
Jan 22, 2010 08:46 AM
G0dzArmy
May 18, 2005 02:38 PM
vtecvoodoo
10
Oct 8, 2003 06:45 PM
gsr squirrel
Apr 4, 2003 06:17 AM
275Performance
Oct 29, 2002 06:55 AM
