B16 crx tachometer problem
Old May 13, 2006 | 12:39 PM
LankorDie's Avatar
Loved
Community Favorite
Default B16 crx tachometer problem
I just put a JDM B16a out of a Integra Xsi in my 1988 crx si.
Now the engine runs fine, but for some reason my tachometer will bounce around. Then when I give it gas and the tach is still off the car will run funny b/c it is getting the wrong fuel for the wrong RPM.
I'm still using my stock guage cluster from the crx si. I put the engine in a month ago and this didnt start for two weeks or so, and now it is getting worse...
Anyone have some advice, its very hard to drive the car with this problem!
Here are some pictures of the car, b/c we all love pictures!
Modified by LankorDie at 1:56 PM 5/13/2006
Old May 13, 2006 | 12:43 PM
crxnj's Avatar
Default Re: B16 crx tachometer problem (LankorDie)
does the tachometer bounce really bad at around 3k-4k revs..? its probably the ignitor in the distributor ..
Old May 13, 2006 | 12:50 PM
LankorDie's Avatar
Loved
Community Favorite
Default Re: B16 crx tachometer problem (Mr.speaker)
It doesnt really seem to matter what rpm I'm at.
I'm trying to learn at the same time here, would you mind explaining why it might be the ignitor in the dizzy?
Old May 13, 2006 | 12:57 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LankorDie &raquo;</TD></TR><TR><TD CLASS="quote">It doesnt really seem to matter what rpm I'm at.
I'm trying to learn at the same time here, would you mind explaining why it might be the ignitor in the dizzy?</TD></TR></TABLE>
i dont have any technical explanation or anything,,except my tach was doing how you say and my father suggested ignitor,,so i replaced it and the tach stopped bouncing..
Old May 13, 2006 | 01:00 PM
LankorDie's Avatar
Loved
Community Favorite
Well my friend has a extra dizzy laying around so I will try that tonight.
Anyone else have a idea?
Old May 13, 2006 | 01:37 PM
SomeDude56's Avatar
hows it hard to drive the car witha bouncing tach?.....maybe you should drive normal......or you could go oldschool and watch for your oil pressure to drop if you got the gauge . My bet would be its your dizzy man.
Old May 13, 2006 | 02:26 PM
91jdmhatchback's Avatar
Default Re: B16 crx tachometer problem (SomeDude56)
i just road in the crx. And when it bounces the car wants to die/ shut off. also we replaced the dizzy with a known working one. so i'm thinking maybe the tach is going out. anyone know what might be going on.
thanks
Old May 13, 2006 | 02:42 PM
ludesrv's Avatar
It's more then likely your wiring for the tach. Make sure it's getting a constant voltage, having a bad voltage or a jumping one will make the tach go wild. And if the car wants to die and shut off because the 'tach' is bouncing, it's more then likely the actually rpm that is out of wack. I drove with no fuse in the fuse box for the tach in my 90 Civic, and it ran fine. The actually tach wont make an engine run weird.
Old May 13, 2006 | 03:38 PM
LankorDie's Avatar
Loved
Community Favorite
Default Re: (ludesrv)
so i should check my wiring for the tach. Thanks i will try that next anymore sugestions?
Old May 13, 2006 | 03:46 PM
LankorDie's Avatar
Loved
Community Favorite
Default Re: (LankorDie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">It's more then likely your wiring for the tach. Make sure it's getting a constant voltage, having a bad voltage or a jumping one will make the tach go wild. And if the car wants to die and shut off because the 'tach' is bouncing, it's more then likely the actually rpm that is out of wack. I drove with no fuse in the fuse box for the tach in my 90 Civic, and it ran fine. The actually tach wont make an engine run weird.</TD></TR></TABLE>
I have a 88 so I don't have a fuse for my tach..
Old May 13, 2006 | 04:14 PM
urafag's Avatar
i put a usdm b18c5 in my 1991 crx si and have the same problem i also replaced the dizzy. i tried replacing computers, because sometimes when u have a chiped computer people screw up and it idles wrong. but that wasnot the problem. i did obd0 to obd1 conversation and now im using a p28 chiped for type r . but i still get that problem less contantly though. today i tried to add water into the radiator and guess what no more problem. i figured that the rad is faulty it has air leaks. now wha to do is replace the rad and see if i still get the same problem. tell me what u tried doing maybe well help each other out
Old May 13, 2006 | 04:23 PM
LankorDie's Avatar
Loved
Community Favorite
Default Re: (urafag)
Well my ECU is 100% stock, so that's not the problem.
I don't think the coolent has anything to do with the tach freaking out..
Anyone other idea's?
Old May 13, 2006 | 04:34 PM
urafag's Avatar
if ur saying that the motor is about to shut off as said above it doesnot have anything to do wit ur tach
Old May 13, 2006 | 04:42 PM
LankorDie's Avatar
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urafag &raquo;</TD></TR><TR><TD CLASS="quote">if ur saying that the motor is about to shut off as said above it doesnot have anything to do wit ur tach </TD></TR></TABLE>
I said that when the tach is freaking out, then the car has problems running.
Anyone else?
Old May 13, 2006 | 05:08 PM
143MYVTECEF's Avatar
recheck all your ignition wiring. Theres gotta be a problem there
Old May 13, 2006 | 05:42 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: (143MYVTECEF)
Yeap, it sounds like the pick-up is not coming through. check main plug wiring on your distributor.
Old May 13, 2006 | 08:53 PM
LankorDie's Avatar
Loved
Community Favorite
Default Re: (mar778c)
Alright I will do that tomarrow.
Old May 13, 2006 | 09:07 PM
EF_generation's Avatar
Tip me if I'm wrong but isn't it the crank. pos. Sensor that drives the stock tak and tells the ecu what rpm the motors spinnin to. .
Old May 14, 2006 | 12:45 PM
LankorDie's Avatar
Loved
Community Favorite
Default Re: (el_payaso)
anyone else?
Old Sep 16, 2006 | 05:10 PM
1_slow_crx's Avatar
.... watwas the problem?
Old Sep 16, 2006 | 06:37 PM
jeffruby's Avatar
Default Re: (1_slow_crx)
check all of your ground wires. bad grounds can do some funky ****
Old Sep 16, 2006 | 07:42 PM
1_slow_crx's Avatar
Default Re: (jeffruby)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeffruby &raquo;</TD></TR><TR><TD CLASS="quote">check all of your ground wires. bad grounds can do some funky ****</TD></TR></TABLE>
gournds where?
Old Sep 16, 2006 | 08:50 PM
IndySporty's Avatar
Yeah my 88 Si had the same problem and I dissasenbled the dizzy and the bottom sensor {ckp?} the little coil had come off of its "stud" and the wires were all throughout the dizzy like cotton candy when they spin it out at the fair. I got another dizzy and it was mint.
Old Sep 16, 2006 | 09:39 PM
1_slow_crx's Avatar
Default Re: (IndySporty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IndySporty &raquo;</TD></TR><TR><TD CLASS="quote">Yeah my 88 Si had the same problem and I dissasenbled the dizzy and the bottom sensor {ckp?} the little coil had come off of its "stud" and the wires were all throughout the dizzy like cotton candy when they spin it out at the fair. I got another dizzy and it was mint.</TD></TR></TABLE>
but the car was acting normal?
Old Sep 17, 2006 | 01:59 AM
4thgenhtch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by el_payaso &raquo;</TD></TR><TR><TD CLASS="quote">Tip me if I'm wrong but isn't it the crank. pos. Sensor that drives the stock tak and tells the ecu what rpm the motors spinnin to. . </TD></TR></TABLE>
Nope The Crank Position Sensor only tells the ecu Where the crank is...
There Ya Go
floridarex
Dec 4, 2007 05:42 AM
LankorDie
10
Jun 14, 2007 08:56 AM
Ova duh limit
Apr 30, 2005 11:32 PM
