Installing JDM 1 Piece Headlight problem
Old May 13, 2006 | 11:30 AM
STYLiNxCHiQ_DA9's Avatar
Default Installing JDM 1 Piece Headlight problem
I just received my 1 piece jdm headlight and I started to take off the front bumper and I'm having a little difficulty trying to remove it.
So far I took out the 2 screws on each side of the wheel well ( 2 Phillip screws )
And I also took out the 3 screws underneath the hood where the hood latch is.
Also unbolted the 2 bolts that are directly on the bottom of the bumper.
And last by not least, there's 1 screw that goes directly into the bumper in the middle that is attached to the frame.
What i was wondering is, in order to take off the bumper.. would i need to take off the screws below the headlight on each sides?
I'm looking at the helms manual flipping though 1031 pages but can't find crap on the front bumper removal.
Input will help greatly.
here's a ghetto picture I edited of where the screws/bolts are at. The YELLOW dots is the bolt underneath the headlight which i can't seem to access. I'm wondering if those need to come off too.
The bumper held pretty tight even though I took out all the red bolts/screws besides the one where the yellow dot is at..
frustration.
Old May 13, 2006 | 11:37 AM
projectTeG's Avatar
your doing it wrong, under the bumper there are a few bolts that bolt it to the crossmember, the the are the 2 screws in each wheel well, then you have to remove the bumper lights and there should be 2 12mm bolts behind each bumper light.
once all of those are removed the bumper should come off.
http://g2ic.com/tegtips/exterior/13.html
this should tell you how to remove the bumper, it also includes how to do a 90-91 to 92-93 front bumpere conversion, but dont mind that.
BTW g2ic.com is your friend
Old May 13, 2006 | 11:40 AM
Default Re: Installing JDM 1 Piece Headlight problem (STYLiNxCHiQ_DA9)
Dammit **** me off. I'll go take another look.
Old May 13, 2006 | 02:26 PM
importdude2000's Avatar
take ur bumper lights off
there is 2 bolts each side
after theose take 2 screws from each well
+a few 10mm bolts under the car
the bumper should come off now
DA's suck cuz the bar is stuck to bumper so its heavy.....
racerxfactor
Mar 12, 2007 05:08 AM
ergot
May 3, 2005 02:22 PM
rcktmn411
Oct 9, 2004 03:40 PM
specie
Jan 23, 2004 12:23 PM
AGB5901
15
Nov 24, 2003 06:31 PM
