air coming out vents when the switch is on OFF.
Old May 13, 2006 | 09:41 AM
mrdeadman's Avatar
They let me pick
Default air coming out vents when the switch is on OFF.
when im driving and my air is on the OFF position it still blows air in, really noticeable when i have it on heat, but if anyone can point me in the right direction, does this happen to all tegs? 3rd gen btw, i just want to know what's up with it. i can live with it if i can't fix it.
Old May 13, 2006 | 09:46 AM
cm zak's Avatar
Happens here to, just a light constant puff thing
Old May 13, 2006 | 09:47 AM
98-DC4's Avatar
Default Re: air coming out vents when the switch is on OFF. (mrdeadman)
i have the same thing with my 98. It's kind of annoying but i think it might be normal.
Old May 13, 2006 | 09:57 AM
89a6T's Avatar
its normal, ive had 20+ hondas and they all do it...if you want the car to be cool put on cold and viceversa...cuz the blower wont be on but air is still being forced through system for some reason and it comes out to whatever temp. the dail was last set on.
Old May 13, 2006 | 10:05 AM
b16adx's Avatar
also make sure you have the re-circulate button pressed. if not air will come in through the vents while your moving....
Old May 13, 2006 | 10:24 AM
Dogginator's Avatar
Daisy... Daisy...
Vehicles are designed to have constant ventilation so that you don't asphyxiate. There are vent flaps in the trunk area to ensure this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16adx &raquo;</TD></TR><TR><TD CLASS="quote">also make sure you have the re-circulate button pressed. if not air will come in through the vents while your moving....</TD></TR></TABLE>
Good idea.
Lithel
Oct 3, 2023 12:51 AM
Reebok4146
Honda Civic (2001 - 2005)
Aug 23, 2008 03:53 PM
NoEx00
Mar 8, 2007 07:31 PM
hookedonvtec
Oct 19, 2005 05:52 PM
JDM_Type-R
Sep 12, 2003 02:47 AM
