5 speed swap ?? throttle cable/spring problem
Old May 13, 2006 | 08:12 AM
hb_guy's Avatar
Default 5 speed swap ?? throttle cable/spring problem
i am done with my 5 speed swap.
i swapped the auto pedal onto the 5 speed pedal set to re-use my throttle cable.
the throttle cable worked fine before now my throttle gets stuck once i hit the gas.
i believe i rehooked the spring incorrectly. can anyone snap a pic of the right way to put it on as i don't remember once i had everything apart.
i will take a pic now and post it ina few minutes, maybe that will help me out as well. thanks
Old May 13, 2006 | 08:16 AM
hb_guy's Avatar
Default Re: 5 speed swap ?? throttle cable/spring problem (hb_guy)
hope this helps you help me!
Old May 13, 2006 | 08:25 AM
jdm206's Avatar
does your pedal still work if you put your spring there? Because when my pedal assembly broke i had to change it. and i put my spring in a different spot
Old May 13, 2006 | 10:52 AM
hb_guy's Avatar
Default Re: 5 speed swap ?? throttle cable/spring problem (jdm206)
just got it fixed, different cable, but my throttle is jumpy when i hit the gas.. any ideas.
keith1993may
Apr 18, 2013 08:10 PM
FOMULA91
Oct 7, 2006 12:39 PM
CimorelliCRX
Sep 8, 2002 09:57 PM
