Recommended Throttle Body
Old May 13, 2006 | 07:25 AM
confutatis's Avatar
Default Recommended Throttle Body
Hello to all...
My stepson is considering purchasing a throttle body for gis '96 Integra GSR and was wondering if he could get some recommendations from those of you who have equipped your Integra with a TB. He was also wondering if the BBK 70mm throttle body would be a good choice?
Thanks to all for your help,
David
Old May 13, 2006 | 08:27 AM
Dr Pooface's Avatar
Default Re: Recommended Throttle Body (confutatis)
stock bored out my maxbore.com
Old May 13, 2006 | 09:55 AM
itr1244's Avatar
Default Re: Recommended Throttle Body (Dr Pooface)
i thought stock TB is good enough for stock to mild build
Old May 13, 2006 | 10:07 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by confutatis &raquo;</TD></TR><TR><TD CLASS="quote">Hello to all...
David</TD></TR></TABLE>
Please tell us what else has been done to the motor. A throttle body would be one of the last things you'd do to a car to get two or three HP with tuning, HP that might make the difference in winning a race.
It won't give you the most HP/dollar unless you're at the end of the development trail.
Old May 14, 2006 | 08:24 AM
confutatis's Avatar
Default Re: Recommended Throttle Body (George Knighton)
Hello,
Quite honestly, I didn't realize that a Tb upgrade would net so few HP. That being the case, what do you recommend should be done to the engine from a-z? Currently. he's only replaced the air intake, upgraded the exhaust and has headers ready to be installed. He also was wondering about who sells the best intake manifold for the GSR and how difficult it is to install it.
Thanks for your thoughts. It's very much appreciated.
Regards,
David
Old May 15, 2006 | 08:11 AM
confutatis's Avatar
Just bumping this up.
Old May 15, 2006 | 08:24 AM
mcclungd2000's Avatar
Skunk 2, bbk, OBX, all make a great intake manifold. but i wouldn't recommend a intake manifold on a gsr until some internal work is done. At least a mild cam upgrade. You can pick up ITR/CTR cams for fairly cheap if you look around. If you do get a single plenum intake manifold you will lose some power down lower in the RPMS and gain it up top like 6-8K with a bolton GSR. Like i said, go with a cam upgrade (along with valve retainers and dual springs) before the throttle body or intake manifold to maximize the power gains with a new manifold and/or throttle body.
Old May 15, 2006 | 08:30 AM
Rickdrizzle's Avatar
Default Re: Recommended Throttle Body (mcclungd2000)
i couldnt agree more.
Old May 15, 2006 | 10:17 AM
EB90RS's Avatar
yea my friend had a gsr with all the boltons and just a intake manifold and TB.... and i have a 90 teg RS with just a clutch, skunk 2 cams, and intake.... and i was smoking him all day so i wouldnt recommend getting just an intake manifold or TB untill you modify more
Old May 15, 2006 | 10:26 AM
96 GSR-T's Avatar
Default Re: Recommended Throttle Body (EB90RS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EB90RS &raquo;</TD></TR><TR><TD CLASS="quote">yea my friend had a gsr with all the boltons and just a intake manifold and TB.... and i have a 90 teg RS with just a clutch, skunk 2 cams, and intake.... and i was smoking him all day so i wouldnt recommend getting just an intake manifold or TB untill you modify more</TD></TR></TABLE>
So you are trying to say your non-vtec RS with cams and an intake was smoking a GSR with all the boltons......
Old May 15, 2006 | 03:16 PM
Ruben19's Avatar
i made 200whp with my fully built motor and a 64mm maxbore throttle body. im happy with the results
Old May 15, 2006 | 03:31 PM
96 GSR-T's Avatar
Default Re: (Ruben19)
Whats with all the newbs in here?
dohcMONSTER's Avatar
i made 214 with a stock GSR TB. (see sig)
Old May 15, 2006 | 05:06 PM
itr1244's Avatar
Default Re: (dohcMONSTER)
lets say stock IM will support up to good HP rating. maybe it should be the last mod to sqeeze out the last Few Hp..
jdmcivicferio
Feb 3, 2004 09:49 AM
