Question about Type R pistons in a B16A2
Old May 13, 2006 | 01:27 AM
premo_si's Avatar
Default Question about Type R pistons in a B16A2
This may be a stupid question, but I searched and couldn't find anything. If I installed Type R pistons in my B16A2, would I be able to use my ECU that came in my car(2000 Si)? And would it pass emissions?
Old May 13, 2006 | 04:10 AM
b18sihatch's Avatar
Default Re: Question about Type R pistons in a B16A2 (premo_si)
yes you should be able to use your stock oem ecu, only difference is the high compression you will yeild from the type r pistons
Old May 13, 2006 | 08:03 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Question about Type R pistons in a B16A2 (b18sihatch)
CTRs? will work great.. you'll lose compression with ITRs.
Old May 13, 2006 | 08:34 PM
Ruben19's Avatar
you are currently runing pr3 pistons
with the ctr piston your compression will be around 10.8-11
with ITR piston you will loose power
Old May 13, 2006 | 10:31 PM
premo_si's Avatar
Default Re: (Ruben19)
yea, sorry I should've said that. CTR's are what I'm thinking of doing.
Ferarrikiller
Sep 12, 2008 05:07 AM
tegra2G
Jul 1, 2008 07:30 PM
raphael
May 5, 2006 10:46 PM
fstassgsr
Aug 31, 2004 01:37 PM
